Meraki SFp Compatibilty
Milind7
I need to connect the Meraki switches below on single-mode fiber. We tried all the combinations, including swapping cables and changing SFPs, unfortunately, it won't work. Could anyone help me which SFP is compatible?
switch model: MS225-24 ---->> MS350-24X
Torbjørn
You can use the Optics Compatability matrix to find this. Here's the list of compatible SFPs for the MS225-24  and the MS350-24X. For single mode you need to find one of the SFPs of media type "SMF".
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
balaji.bandi
what SFP you used and what speed.
I have tried 10G-SR and 1G-LH works as expected
BB
Milind7
tried MA-SFP-1GB-SXMA-SFP-10GB-SR , GLC-SX-MM COM and GLC-TE
You mentioned Single mode Fibre - i take is as OS" ( not OM4 or OM ?)
MA-SFP-1GB-SXMA-SFP-10GB-SR , GLC-SX-MM COM  ( all are MM fibre requirement, so that is not going to work for you using SMF ?)
GLC-T  - with Ethernet should work - if the distance is not an issue ?
either try MM fibre patch you to test.
BB
