MIB Extension - Cisco Catalyst 2960 -
a.benhima
Hi everyone,
I would like to monitor a cisco catalyst 2960 provided with IOS v15. I accessed mib files and I found that many component are disabled or have no entry in it (check attachment).
So my question is : Can I extend the mib to support more OIDs ? and if so, I'll be glad if you give a tutorial or example !
Thank you so much.
Best regards,
Kevin Dorrell
Level 10
Level 10
Your ipRouteTable and EGP MIBs are disabled because the 2960 is a layer-2 switch only, so it does not have any ip routing or EGP.  The MIBs will be disabled for features your switch does not support.
Kevin Dorrell
Luxembourg
Kevin Dorrell
Level 10
Level 10
Kevin Dorrell
Luxembourg
