08-25-2014 03:51 AM - edited 03-07-2019 08:30 PM
Hi all
Here is my ntp configuration
clock timezone GMT 4
clock summer-time UAE recurring
ntp server 192.168.10.254 version 2 prefer
end
sh ntp status
Clock is unsynchronized, stratum 16, no reference clock
nominal freq is 119.2092 Hz, actual freq is 119.2092 Hz, precision is 2**17
reference time is 00000000.00000000 (04:00:00.000 GMT Mon Jan 1 1900)
clock offset is 0.0000 msec, root delay is 0.00 msec
root dispersion is 0.00 msec, peer dispersion is 0.00 msec
-SW1#sh ntp associations
address ref clock st when poll reach delay offset disp
~192.168.10.254 0.0.0.0 16 - 64 0 0.0 0.00 16000.
* master (synced), # master (unsynced), + selected, - candidate, ~ configured
-SW1#
Please help me what i have did wrong
regards
raja
08-25-2014 04:52 AM
Let's go with the basic.
First, 192.168.10.254, is this a synchronized NTP/SNTP source?
Next, NTP version 2, would it make a difference?
08-25-2014 05:17 AM
HI
My switch ip is 192.168.10.254 i need to make that as my ntp server for all my network devices
Please can you give the configuration
08-25-2014 08:04 AM
Hello
Is that device setup as a ntp master?
example:
NTP Master:
conf t
ntp master 12
ntp master
ntp max-associations xx
clock update-calendar
clock read-calendar
ntp authenticate
ntp authentication-key 931 md5 ntppassword
ntp trusted-key 931
NTP clients
conf t
ntp peer
ntp server 192.168.10.254 prefer
ntp authenticate
ntp trusted-key 931
res
Paul
08-25-2014 09:05 PM
You're still not answering the question: Is the appliance, with IP Address 192.168.0.254, synchronized with a valid SNTP/NTP address or not.
If the answer is no, then NTP to the downstream device will be "quasi" or not-really-trusted.
08-25-2014 09:08 PM
Hi leo
I need to make the switch 192.168.10.254 as ntp server
08-26-2014 05:12 AM
You are still not answering the question.
Is the appliance, with IP Address 192.168.10.254, synchronized with a valid SNTP/NTP address or not.
Even if you enable NTP Master (which I personally don't recommend) and your appliance is NOT synchronized to a valid NTP source, then the appliance 192.168.10.254 can potentially broadcast the WRONG time to all the appliance. Since you've forced all downstream appliances to synchronize with a source that has the wrong NTP data (using the command "ntp master") all your network equipment will be sporting the wrong time.
