mirror a port
ohareka70
Level 3
Level 3
At moment I have mirrored a single port and am pointing the data back to the netflow server:
  • monitor session 2 source interface Gi1/0/28 (data I want to capture)
  • monitor session 2 destination interface Gi1/0/17 (mirrored port)
Is it possible though to mirror a Port-channel1 (trunk port)?
  • interface Port-channel1
  • switchport trunk encapsulation dot1q
  • switchport mode trunk
Is it also possible to mirror a VLAN?
  • vlan 226
  • name SAN
  • if so does anyone have the config for both?
2 Accepted Solutions
nawas
Level 4
Level 4
Yes, you can monitor a port channel, matter of fact if a physcial is part of a port channel you would have to add its port
channel in your source span using the following
  • monitor session 2 source interface port-chanenl-1 (mirrored port)
Use the following command for vlan span
switch(config)#monitor sess 2 source vlan ?
  <1-4094>  SPAN source VLAN
cadet alain
yes you can do SPAN for a portchannel as source only and for vlan also.
so just specify interface port-channel 1 in source or the vlan you want to monitor.
Regards.
Alain
nawas
Level 4
Level 4
cadet alain
Regards.
Alain
thanks for the advice - spot on.
regards,
Kevin
