Mirroring (SPAN) on Switch WS-C3750-24TS
MarcoM
Hi all,
i have a switch WS-C3750-24TS with release 12.2(20)SE3.
I would like to create a span port and to be able to mirror only the vlan interested.
I added these two commands to configuration:
monitor session 1 source vlan 1 , 200
monitor session 1 destination interface Fa1/0/24
but on destination port i receive always traffic untagged.
So i read on other forum to enable this command:
monitor session 1 destination interface Fa1/0/24 encapsulation replicate
but also with this command the result is the same.
Is there a way to get packets tagged on the destination port of span? is a limitation of this switch?
Thanks in advance.
8 Replies 8
Hi Marco,
I saw that you have tried "monitor session 1 destination interface Fa1/0/24 encapsulation replicate". Have you tried while configuring the destination port (fa1/0/24) as a 'trunk' port?
HTH,
Meheretab
HTH,
Meheretab
Hi Meheretab,
i tried to configure destination port as trunk but no avail:
interface FastEthernet1/0/24
 switchport mode trunk
Any ideas?
Marco
Mark Malone
is your destination port set as trunk and are you spanning a trunk port as a source too
see this too may help
https://wiki.wireshark.org/CaptureSetup/VLAN
Hi Mark,
i need to span only vlan defined on switch (in this case tag 1 and tag 200), so i defined only trunk destination port no other source port defined as trunk. Makes sense?
Marco
I thought from memory you need to span a physical trunked interface to receive tagged packets , the vlan wont suffice , I think you need to span the trunk itself to see tags
looking at another post there saying same thing there needs to be a source set as trunk , you could easily test it to see , if its only those vlans you can filter on span too
https://supportforums.cisco.com/t5/lan-switching-and-routing/span-traffic-with-vlan-tag/td-p/2128464
Hi Mark,
I have the same problem that the user had.
When configure span on destination port i have only this option:
Switch(config)#$sion 1 destination interface Fa1/0/24 encapsulation ?
  replicate  interface replicates source encapsulation
the dot1q option is not available. I tried to configure source port with trunk but without results.
I do not understand if the problem is related to the switch model or anything else.
Marco
MarcoM
Hi all,
so for this switch model you can not have a span port with tagged vlans?
Thanks.
sorry slow reply I checked several 37s I have in production none of them seem to have that statement available to configure , if you check the feature navigator it may confirm further
http://cfn.cloudapps.cisco.com/ITDIT/CFN/
