Missing next hops
Patrick McHenry
Level 7
Level 7
I posted this question before - hoping to have better luck this time. Can someone explain to me why I'm missing next hops on some of these routes?
Thank you
O E2     10.3.8.159/32 [110/20] via 172.20.64.3, 1d16h, GigabitEthernet0/0/0
O E2     10.3.8.165/32
O E2     10.3.8.166/32
O E2     10.3.8.167/32
O E2     10.3.8.168/32
O E2     10.3.8.169/32
O E2     10.3.8.170/32
O E2     10.3.8.171/32
If the next hop information string is too long for that line it may be getting bumped to the next line of output.  If thats the case the information is not displayed as only the line matching the " | include " is displayed.
So for instance output like this:
O E2     10.3.8.165/32
When processed with a "| include 10.3.8"  would show this:
O E2     10.3.8.165/32
Because the
line does not contain a "10.3.8", even though it typically falls on the same line, will not be shown.
I would just do a full "show ip route" and eyeball that for what you are looking for to see if thats actually whats happening.
- Be sure to rate all helpful posts
First let's find out if there is really no next-hop. What was the *exact* show-command to grab this output?
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
Show ip route | i 10.3.8. was the command to get the output.
When I do a show ip route 10.3.8.165 I get the next hop.
Thanks, PAt.
O E2     10.3.8.165/32
O E2     10.3.8.165/32
Because the
aahh........ thanks.
