module 9 mismatch
mahesh18
Level 6
Level 6
when i do sh mod 9 on switch
sh mod 9
Mod Slot Ports Module-Type Model Sub Status
9 9 24 10/100BaseTX Ethernet WS-X5224 no ok
Module 9 mismatch of config and actual type. Ports disabled
Config: 48 port 10BaseT (Telco) , Actual: 10/100BaseTX Ethernet
Insert config module type or do a 'clear config 9'
Mod Module-Name Serial-Num
9 00018464554
Mod MAC-Address(es) Hw Fw Sw
9 00-30-b6-2a-ee-48 to 00-30-b6-2a-ee-5f 1.5 3.1(1) 5.5(15)
what does this mean?
also log shows
sh mod 9
9 00018464554
also log shows
2008 Sep 18 17:10:35 CST -05:00 %SYS-3-MOD_CFGMISMATCH2:*Config:48 port 10BaseT (Telco)
2008 Sep 18 17:10:35 CST -05:00 %SYS-3-MOD_CFGMISMATCH3:*Actual:10/100BaseTX Ethernet
2008 Sep 18 17:10:35 CST -05:00 %SYS-3-MOD_CFGMISMATCH4:Insert config type module or do a 'clear config 8'
2008 Sep 18 17:10:37 CST -05:00 %SYS-5-MOD_OK:Module 8 is online
2008 Sep 18 17:10:52 CST -05:00 %SYS-3-MOD_CFGMISMATCH1:Module 9 configuration mismatch. Ports disabled
2008 Sep 18 17:10:52 CST -05:00 %SYS-3-MOD_CFGMISMATCH2:*Config:48 port 10BaseT (Telco)
2008 Sep 18 17:10:52 CST -05:00 %SYS-3-MOD_CFGMISMATCH3:*Actual:10/100BaseTX Ethernet
2008 Sep 18 17:10:52 CST -05:00 %SYS-3-MOD_CFGMISMATCH4:Insert config type module or do a 'clear config 9'
2008 Sep 18 17:10:55 CST -05:00 %SYS-5-MOD_OK:Module 9 is online
any help?
thanks
Correct. You should remove the new blade (if already installed) and then "clear config 9". After that then install the new card and configure then new interfaces. It shows disabled because the existing configuration shows a different card installed.
HTH,
Mark
Mark Yeates
Level 7
Level 7
Did you have a 48 port blade in the switch previously? This means that the config still reflected a 48 port blade in slot 9 and you put in a 24 port blade. Usually you will either need to reboot the switch for the config to clear out the old interface configs or issue the "clear config 9" command.
HTH,
Mark
Hi Mark
thanks for reply
i do had 48 port blade in switch previously.
so i can ran the command clear config 9 that will fix the problem?
also why all ports on module 9 show disabled?
Clear config 9 should fix it , you may have to reload the slot so it recognizes the new card correctly .
HTH,
Mark
