module SM-X-ES3-16-P and vlan 1, 2 internal port with the module switch
duyennv10
I have router isr4331 with SM-X-ES3-16-P module
I connnect a switch 2960  with isr4331 through SM-X-ES3-16-P module by port 16
the connection between switch 2960 (vlan 1 ip :192.168.11.254/24)  and module switch SM-X-ES3-16-P ( int vlan 1: 192.168.11.250/24)
but I cant connect from router ( int vlan 1 ip: 192.168.11.1/24) to module switch through vlan 1
config on module switch SM-X-ES3-16-P :
interface GigabitEthernet0/16
description *** connect to sw 2960 ***
switchport mode trunk
interface GigabitEthernet0/17
switchport protected
interface GigabitEthernet0/18
interface Vlan1
ip address 192.168.11.10 255.255.255.0
config on isr4331:
interface Ethernet-Internal1/0/0
no negotiation auto
service instance 1 ethernet
encapsulation dot1q 1
rewrite ingress tag pop 1 symmetric
bridge-domain 1 split-horizon group 0
interface BDI1
ip address 192.168.11.1 255.255.255.0
If I config  int vlan 1 on isr4331 have ip 192.168.11.1/24, the same problem happen.
I config the same way with other vlan and they work without problem
I havent seen many documents about this switch module
could you help me check the problem
Thank you!
duyennv10
up
How did you fix it?  If you can remember.
