module status & diagnostic result analysis
Youn Seok Kim
Frequent Visitor
Frequent Visitor
i installed WS-C4506-E  3 day ago
i discovered someting different module status
Right at the end of the module ( WS-X4648-RJ45-E ) show red led. this is not port led
i try to reset module several time. but it's same status.
I upload picture..
could plz answer why ?
i guess this is hardware problem but it's not sure..
and this is module status and diagnostic result
do you know what is mean ?
Error code ------------------> 3 (DIAG_SKIPPED)
This Case is DOA(Dead of arrival ?
C4506#sh mod
Chassis Type : WS-C4506-E
Power consumed by backplane : 0 Watts
Mod Ports Card Type                              Model              Serial No.
1     6  Sup 7L-E 10GE (SFP+), 1000BaseX (SFP)  WS-X45-SUP7L-E     ABCDE123456
2    24  1000BaseX (SFP)                        WS-X4624-SFP-E      ABCDE123456
6    48  10/100/1000BaseT (RJ45)                WS-X4648-RJ45-E     ABCDE123456
M MAC addresses                    Hw  Fw           Sw               Status
1 b0fa.ebe5.16c0 to b0fa.ebe5.16c5 1.1 15.0(1r)SG3  03.03.00.SG      Ok
2 b0fa.ebc6.5b70 to b0fa.ebc6.5b87 1.2                               Ok
6 10f3.1197.1490 to 10f3.1197.14bf 2.1                               Ok
module 6:   SerialNo :  ABCDE1234
C4506#
C4506#sh diagnostic result module 6 test 1 detail
Current bootup diagnostic level: minimal
  Test results: (. = Pass, F = Fail, U = Untested)
  ___________________________________________________________________________
    1) linecard-online-diag ------------> .
          Total run count -------------> 1
          Last test testing type ------> n/a
          Last test execution time ----> Mar 23 2013 07:54:17
          First test failure time -----> n/a
          Last test failure time ------> n/a
          Last test pass time ---------> Mar 23 2013 07:54:17
          Total failure count ---------> 0
          Consecutive failure count ---> 0
Slot Ports Card Type                              Diag Status      Diag Details
6    48   10/100/1000BaseT (RJ45)                Passed           None
Detailed Status
. = Pass              U = Unknown
L = Loopback failure  S = Stub failure
P = Port failure
E = SEEPROM failure   G = GBIC integrity check failure
Ports 1   2   3   4   5   6   7   8   9   10  11  12  13  14  15  16
Ports 17  18  19  20  21  22  23  24  25  26  27  28  29  30  31  32
Ports 33  34  35  36  37  38  39  40  41  42  43  44  45  46  47  48
5 Replies 5
Leo Laohoo
Can you  post your "sh log"?
Youn Seok Kim
Frequent Visitor
Frequent Visitor
There is no any log
Thank you
Sent from Cisco Technical Support Android App
No logs?  Re-seat the module.  During the power-up of the module, it'll be logged.  Post that.
Youn Seok Kim
Frequent Visitor
Frequent Visitor
I think this is Hardware Fault so I have processed DOA
Youn Seok Kim
Frequent Visitor
Frequent Visitor
Problem analysis:
I have serach the issue and then found we are hit bug CSCue90589
CSCue90589  WS-X4648-RJ45-E may have Red LED at the far right corner
Symptom:
Certain serial numbers of WS-X4648-RJ45-E  have a Red LED at the far right corner.   This will be visible through the sticker.
Conditions:
Insert a WS-X4648-RJ445-E into a powered up chassis.
Workaround:
The LED will always be Red and will never be green.  It can be ignored.
Here is the bug link:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCue90589
Action plan:
As the bug mentioned, this is not an issue that we can ignore the LED status.
