monitor port only see Layer 2 traffic
chinpohpang851
my source port is a access port with no IP assigned and then i wireshark the dest port I can only see ARP, Broadcast...  I can't see any other traffic passing thru that access port. why?
10 Replies 10
chinpohpang851
can't see any TLS, HTTP, HTTPS or any handshake.
It sounds like you haven't configured a SPAN/monitor session in the switch. It would be normal for a regular access port to only see broadcasts or traffic directed to the local MAC address.
balaji.bandi
post the config and monitor session information
try :
monitor session 1 dest int gig0/1 both   (change the interface as per requirement)
BB
chinpohpang851
Gi1/0/1 is just an layer 2 access port to firewall(gateway) but we can't see session traffic on monitoring port Gi1/0/13.
I want to monitor the traffic out/in to the firewall and to see all kinds of traffic.
Hello
Change the destination port to be a trunk and source from the FW access port vlan
Example:.
interface int Gi1/13
description span session 1 for gig0/1
switchport mode trunk
switchport trunk allowed vlan x (firewall vlan)
monitor session 1 source vlan vlan x (firewall vlan)
monitor session 1 destination interface Gi1/13
Kind Regards
Paul
I've made the changes accordingly but my monitoring Palo Tap mode interface still not capturing anything.
balaji.bandi
how does your config look interface and monitor session
BB
source int
interface GigabitEthernet1/0/1
description To FW port 4
switchport access vlan 1001
switchport mode access
spanning-tree portfast
destination int
interface GigabitEthernet1/0/13
description Palo monitor port
switchport nonegotiate
chinpohpang851
chinpohpang851
