Monitor session
valides007
Level 4
Level 4
I'm trying to monitor and record VoiP calls in my network. These are the commands that i passed on the Switch A
monitor session 1 source vlan 3 both
monitor session 1 destination int gi0/15 ingress vlan 3
vlan 3 is the telephone vlan and port 15 is where the voice recorder is connected.
If the call is between 2 phones on Switch A, monitoring and recording are done perfectly.
If the call is between a phone on Switch A and a phone on other switch i'm getting half monitoring. It's only monitoring on side of the call. The RTP traffic on Ethereal is showing one direction.
Do you have any idea about this issue?
Note: Call Manager Express is also on Switch A
5 Replies 5
Giuseppe Larosa
Hello Walid,
first of all I would change the second command
you have already specified what you want to capture in the first command and the ingress option could introduce some filtering action.
When you try to monitor a call between a phone on switch A and a phone on another switch are both in Vlan3 ?
Hope to help
Giuseppe
Guiseppe,
First i tried the second command without ingress and i'm still getting the same result.
I understand both phones are in Vlan3 and that why i'm getting confused. I don't see why this thing doesn't work.
It seems that whenever there is call between phones from different switches the SPAN is monitoring only 1 direction of the traffic and you can see this clearly on Ethereal.
This is so frustrating.......
HI
I think u need to use RSPAN for this as the devices r connected on different switches.
Mahmood
just to make a try you could try to use as source the physical port where the phone on Switch A is connected with the both options.
In this case you should see both ends of communication in any case.
Of course this is less flexible.
Hope to help
Giuseppe
garytayl
Level 7
Level 7
Lets remember what is the purpose of SPAN:
-Local SPAN supports a SPAN session entirely within one switch; all source ports or source VLANs and destination ports reside in the same switch.
In regards to RSPAN, documentation specifies:
RSPAN supports source ports, source VLANs, and destination ports on different switches, enabling remote monitoring of multiple switches across your network
From the explanation above, RSPAN might help you out, but be aware that RSPAN is not available on the Catalyst 3500, 2900, or 3524-PWR switches.
You may also want to look at following doc with more detail information on how to accomplish this using specialized software:
http://cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00801a62a8.shtml#
Gary
