Monitor stacking ports
discovery26
Community Member
We have 3750 switches and recently we had an issue with cable wasn't plugged in properly. It was hard to see it as it's got a lot of small pins.
I would like to monitor the status of the stacking port. We have appication (Nable) which use SNMP to monitor interface health. Unfortunately I couldn't find OID for stack ports.
Is there any other way to monitor the status of those ports?
chrebert
Level 9
Level 9
You have posted in the Small Business Support forums, and we don't usually support Catalyst switches.  You will probably have better luck getting a good answer if you move your post to the Network Infrastructure - LAN Switching forum.
Thank you for choosing Cisco,
Christopher Ebert - Advanced Network Support Engineer
Cisco Small Business Support Center
