monitoring a port
csanchez
Level 3
Level 3
I have set up a monitoring session on a 4507 switch. The intent for this session is to capture all internet traffic for filtering purposes. I configured the session using the following commands:
monitor session 1 source int "port"
monitor session 1 dest int "port"
The status indicates that the destination port is not receiving packets and it is not learning.
The interface on my filtering unit stops responding and I am wondering if I misseed something on my session that may be causing the interface to stop responding.
TIA.
surojitmitra
Community Member
try the following
monitor session 1 source int `port` ?
monitor session 1 source int `port` tx, rx, both
rest is fine you can try this it should work
Thanks, that help.
