TTY ine
dhavaltandel
Level 4
Level 4
Hello All,
Can i set the absolute-timeout command for TTY line on cisco router.
i check for VTY line its working.
i need the user to get disconnect within couple of time on TTY line.
thanks
dhaval tandel
Amit Singh
Dhaval,
Absolute time-out command is only used for VTY lines.
You can use session-timeout command to logout user after an ideal time out.
Router(config-line)# session-timeout minutes
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/ftersv_c/dcdtrmop.htm#wp1000983
HTH,
-amit singh
