Monitoring Web Activity
samirshaikh52
Level 7
Level 7
Hello Experts,
We have a small network for our college.
ADSL------> Cisco Router-----Cisco Switch----Wireless Access Points.
I want to monitor internet activity of all staff....basically a report on users using the sites and bandwith.
Thanks.
Samir
Hello Samir,
You can use cisco netflow option (if available in your router IOS). Check the below link.
http://www.cisco.com/en/US/docs/ios/12_0s/feature/guide/nfstatsa.html
Or if budget permits, you can go with a proxy server and deploy in transperant mode.
Hth
MS
5 Replies 5
Glenn Matthys
Level 3
Level 3
That totally depends on what actual hardware you have. One possible scenario would be to set up a SPAN session (SwitchPort ANalyzer) which all traffic flows through (monitor the link between the switch and the router) and capture that information using ntop (http://www.ntop.org/products/ntop/)
zoltanszasz
Level 2
Level 2
implement ClearOS in the network
Hello Samir,
Hth
MS
I configured ISA Server in transparent mode and used as a SecureNAT Client. Confgured Clients Gateway pointing to ISA Server.
Thanks for your support.
simionov.adrian
Level 3
Level 3
I would try NTOP on a server. For your ADSL traffic will create really nice statistics.
http://www.ntop.org
