MPLS Traffic Engineering - Tunnels not coming up.
mac_mac_net83
So I have a network setup and everything seems to work fine.
I have 3 OSPF areas and running MPLS VPN (MP - BGP all configured)
Area 65 ---- Area 0 ----- Area 78
I am trying to create a tunnel from one router in Area 65 to another router in router 78.
Take note that all routers partcipating on reach respective areas are configured with:
   mpls traffic-eng area <area-id>  as well as mpls traffic-eng roouter-id <interface>
All interfaces on the core are configured with mpls traffic-eng tunnels as well as the ip rsvp bandwidht command.
Below are the results I get when I configure just a simple tunnel fom a router in Area 65 to a router going to Area 78.
R5#show running-config interface tunnel 57
Building configuration...
Current configuration : 156 bytes
interface Tunnel57
ip unnumbered Loopback0
tunnel mode mpls traffic-eng
tunnel destination 7.7.7.7
tunnel mpls traffic-eng path-option 1 dynamic
end
R5#
interface Loopback0
ip address 5.5.5.5 255.255.255.255
end
R5#ping 7.7.7.7 source lo0
Sending 5, 100-byte ICMP Echos to 7.7.7.7, timeout is 2 seconds:
Packet sent with a source address of 5.5.5.5
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
R5#
R5#show mpls traffic-eng tunnels
Name: R5_t57 (Tunnel57) Destination: 7.7.7.7
Status:
Admin: up Oper: down Path: not valid Signalling: Down
path option 1, type dynamic
Config Parameters:
Bandwidth: 0 kbps (Global) Priority: 7 7 Affinity: 0x0/0xFFFF
Metric Type: TE (default)
AutoRoute: disabled LockDown: disabled Loadshare: 0 bw-based
auto-bw: disabled
History:
Tunnel:
Time since created: 14 hours, 16 minutes
Time since path change: 13 hours, 57 minutes
Number of LSP IDs (Tun_Instances) used: 1732
Prior LSP:
ID: path option 1 [40]
Removal Trigger: configuration changed
Last Error: PCALC:: Destination IP address, 7.7.7.7, not found
I can't figure it out why the output is saying 7.7.7.7 cannot be found but, that /32 route is in the routing table and is reachable from this router.
Any comments are appreciated.
Thanks.
Mark
13 Replies 13
Reza Sharifi
Does every router in the path have these commands in the OSPF config?
mpls traffic-eng router-id Loopback0
mpls traffic-eng area x
yes, there is, also for the ABRs, is like below:
router ospf 1
mpls traffic-eng area 0
mpls traffic-eng area 65
Harold Ritter
Hi Mark,
You can't use the dynamic path-option between area. The issue is that the head end router does not have all the information to calculate the entire path to the tail end, as they are not in the same area. You need to use an explicit path-option, as explained in this document.
https://www.cisco.com/c/en/us/td/docs/ios/12_0s/feature/guide/fs_areat.html#wp1034833
HI harold, thanks for the reply.
I have tried that option (using explicit paths with strict and loose) and it fails as well, Let me try again later and see if to reset the tunnel as well.
Also, my "show mpls traffic-eng topology " output for each routers shows that it is learning all the nodes within the areas, so I think there should be no problem of having the tunnels up . let me try again later. Thanks for the inputs.
Hi Mark,
The following error message "Last Error: PCALC:: Destination IP address, 7.7.7.7, not found" is basically telling you that the information for the tail-end router is not present in the head end router topology database.
The MPLS traffic engineering topology information is advertised via opaque LSAs and these LSAs have a scope of area, which means they will not propagate outside of the local area. So I do not know how MPLS traffic engineering information could be present on all routers given your multi area topology.
HI Harold,
I am pretty sure, it should work still is using multiple areas that is why it is the reason why you need to specify the areas for the mpls traffic engineering under the routing protocol you are using in the network, not sure if this is an issue with the simulator, so I am still trying and running debugs of what could be the cause....
mark
Have you verified if RSVP is configured under the interfaces over the path?
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Hi Harold,
Ye. The RSVP bw are already configured. It is configured with 2M . I have 10M core links across the network and rarely used, does it pose any issue?
Mark
Hi Mark,
It will not work. The reason you specify the area is to tell OSPF what area should be using the MPLS TE extensions. OSPF still won't propagate TE information from one area to the other. You should be able to verify that even in your simulated lab.
Hi Harold,
In our production network, we are using OSPF multi area and was able to setup MPLS traffic engineering tunnels all over the place...
Mark
You must be using the Inter Area MPLS TE feature then. Check your production config to see whether you use a dynamic or explicit path.
mailatgk
Hi ,
I am seeing same kind of issue. Tunnel is not coming up .
I am using XRV node running version 7.11.2.  Could anyone please comment on this issue ?
XRV-A Config:
RP/0/RP0/CPU0: XRv-A#show running-config interface tunnel-te 7
Wed May  8 07:34:55.889 UTC
interface tunnel-te7
 description RSVPtunnel
 ipv4 unnumbered Loopback0
 signalled-name XRV-A
 autoroute announce
 destination 92.168.96.24
RP/0/RP0/CPU0:XRv-A#show running-config router ospf 1
Wed May  8 06:19:12.705 UTC
router ospf 1
 router-id 92.168.96.26
 redistribute connected
 area 0.0.0.0
  mpls traffic-eng
  interface GigabitEthernet0/0/0/2.10
   network point-to-point
RP/0/RP0/CPU0:XRv-A#show running-config rsvp
Wed May  8 06:19:36.765 UTC
rsvp
RP/0/RP0/CPU0:XRv-A#show running-config mpls traffic-eng
Wed May  8 06:19:42.471 UTC
mpls traffic-eng
RP/0/RP0/CPU0: :XRv-A#show running-config interface loopback 0
Wed May  8 06:32:08.518 UTC
interface Loopback0
 ipv4 address 92.168.96.26 255.255.255.255
RP/0/RP0/CPU0:XRv-A#show running-config interface GigabitEthernet0/0/0/2.10
Wed May  8 07:43:16.876 UTC
 ipv4 address 10.10.15.1 255.255.255.252
 encapsulation dot1q 10
RP/0/RP0/CPU0: XRv-A#show ospf neighbor
Wed May  8 06:53:28.103 UTC
* Indicates MADJ interface
# Indicates Neighbor awaiting BFD session up
Neighbors for OSPF 1
Neighbor ID     Pri   State           Dead Time   Address         Interface
92.168.96.24    1     FULL/  -        00:00:37    10.10.15.2      GigabitEthernet0/0/0/2.10
    Neighbor is up for 00:26:29
RP/0/RP0/CPU0:XRv-A#show mpls traffic-eng tunnels 7
Wed May  8 07:44:29.749 UTC
Name: tunnel-te7  Destination: 92.168.96.24  Ifhandle:0x1c
  Signalled-Name: XRV-A
  Status:
    Admin:    up Oper: down   Path:  valid   Signalling: RSVP signaling proceeding
    G-PID: 0x0800 (derived from egress interface properties)
    Bandwidth Requested: 0 kbps  CT0
    Creation Time: Tue May  7 06:28:17 2024 (1d01h ago)
  Config Parameters:
    Bandwidth:        0 kbps (CT0) Priority:  7  7 Affinity: 0x0/0xffff
    Metric Type: TE (global)
    Path Selection:
      Tiebreaker: Min-fill (default)
    Hop-limit: disabled
    Cost-limit: disabled
    Delay-limit: disabled
    Delay-measurement: disabled
    Path-invalidation timeout: 10000 msec (default), Action: Tear (default)
    AutoRoute:  enabled  LockDown: disabled   Policy class: not set
    Forward class: 0 (not enabled)
    Forwarding-Adjacency: disabled
    Autoroute Destinations: 0
    Loadshare:          0 equal loadshares
    Load-interval: 300 seconds
    Auto-bw: disabled
    Auto-Capacity: Disabled:
    Self-ping: Disabled
    Fast Reroute: Disabled, Protection Desired: None
    Path Protection: Not Enabled
    BFD Fast Detection: Disabled
    Reoptimization after affinity failure: Enabled
    Soft Preemption: Disabled
  History:
    Current LSP:
      Setup Time: 57 seconds
    Reopt. LSP:
      Last Failure:
        Re-opt LSP signalling time-out
        Date/Time: Tue May 07 10:54:59 UTC 2024 [20:49:30 ago]
        First Destination Failed: 92.168.96.24
    Prior LSP:
      ID: 298 Path Option: 1
      Removal Trigger: setup timed out
  Path info (OSPF 1 area 0.0.0.0):
  Node hop count: 1
  Hop0: 10.10.15.2
  Hop1: 92.168.96.24
LSP Tunnel 92.168.96.24 7 [301] is signalled, Signaling State: up
  Tunnel Name: XRV-B Tunnel Role: Tail
  InLabel: GigabitEthernet0/0/0/2.10, implicit-null
  Signalling Info:
    Src 92.168.96.24 Dst 92.168.96.26, Tun ID 7, Tun Inst 301, Ext ID 92.168.96.24
    Router-IDs: upstream   92.168.96.24
                local      92.168.96.26
    Bandwidth: 0 kbps (CT0) Priority:  7  7 DSTE-class: 0
    Soft Preemption: None
    SRLGs: not collected
    Path Info:
      Incoming Address: 10.10.15.1
      Incoming:
      Explicit Route:
        Strict, 10.10.15.1
        Strict, 92.168.96.26
      Record Route: Disabled
      Tspec: avg rate=0 kbits, burst=1000 bytes, peak rate=0 kbits
      Session Attributes: Local Prot: Not Set, Node Prot: Not Set, BW Prot: Not Set
                          Soft Preemption Desired: Not Set
    Resv Info: None
      Fspec: avg rate=0 kbits, burst=1000 bytes, peak rate=0 kbits
Displayed 1 (of 1) heads, 0 (of 0) midpoints, 1 (of 1) tails
Displayed 0 up, 1 down, 0 recovering, 0 recovered heads
RP/0/RP0/CPU0:XRv-A#show interfaces tunnel-te 7
Wed May  8 08:05:36.859 UTC
tunnel-te7 is down, line protocol is down
  Interface state transitions: 4
  Hardware is Tunnel-TE
  Description: RSVPtunnel
XRV-B config:
RP/0/RP0/CPU0:XRv-B#show running-config interface gigabitEthernet 0/0/0/2.10
Wed May  8 07:58:54.490 UTC
 ipv4 address 10.10.15.2 255.255.255.252
RP/0/RP0/CPU0:XRv-B#show running-config interface loopback 0
Wed May  8 07:59:33.424 UTC
interface Loopback0
 ipv4 address 92.168.96.24 255.255.255.255
RP/0/RP0/CPU0:XRv-B#show ospf neighbor
Wed May  8 07:59:52.277 UTC
92.168.96.26    1     FULL/  -        00:00:37    10.10.15.1      GigabitEthernet0/0/0/2.10
    Neighbor is up for 2w0d
Total neighbor count: 1
RP/0/RP0/CPU0:XRv-B#show running-config router ospf 1
Wed May  8 08:00:16.799 UTC
router ospf 1
 router-id 92.168.96.24
 address-family ipv4 unicast
 area 0.0.0.0
  mpls traffic-eng
  interface Loopback0
RP/0/RP0/CPU0:XRv-B#show running-config rsvp
Wed May  8 08:00:49.427 UTC
\rsvp
RP/0/RP0/CPU0:XRv-B#show running-config mpls traffic-eng
Wed May  8 08:00:54.751 UTC
mpls traffic-eng
RP/0/RP0/CPU0:XRv-B#show mpls traffic-eng tunnels 7
Wed May  8 08:02:52.520 UTC
Name: tunnel-te7  Destination: 92.168.96.26  Ifhandle:0x1c
  Signalled-Name: XRV-B
  Status:
    Creation Time: Tue May  7 09:37:58 2024 (22:24:54 ago)
  Config Parameters:
    Path Selection:
    Hop-limit: disabled
    Auto-bw: disabled
    Self-ping: Disabled
  History:
    Current LSP:
      Setup Time: 49 seconds
    Prior LSP:
      ID: 304 Path Option: 1
  Node hop count: 1
  Hop0: 10.10.15.1
  Hop1: 92.168.96.26
LSP Tunnel 92.168.96.26 7 [303] is signalled, Signaling State: up
  Tunnel Name: XRV-A Tunnel Role: Tail
  Signalling Info:
    Src 92.168.96.26 Dst 92.168.96.24, Tun ID 7, Tun Inst 303, Ext ID 92.168.96.26
    Router-IDs: upstream   92.168.96.26
                local      92.168.96.24
    Path Info:
      Incoming Address: 10.10.15.2
      Incoming:
      Explicit Route:
        Strict, 10.10.15.2
        Strict, 92.168.96.24
    Resv Info: None
RP/0/RP0/CPU0:XRv-B#show running-config interface tunnel-te 7
Wed May  8 08:02:59.789 UTC
 description RSVPtunneltoA
 signalled-name XRV-B
 autoroute announce
 destination 92.168.96.26
RP/0/RP0/CPU0:XRv-B#show interfaces tunnel-te 7
Wed May  8 08:06:11.917 UTC
  Interface state transitions: 0
Make new post is better
MHM
