msec on syslog messages
rasmus.elmholt
Level 7
Level 7
Hi.
I have a switch where I am testing some STP logging and debugging.
I have enabled STP logging and trap generation on the switch and on links.
Now I want to make sure all messages are with the msec stamp on logs.
I have enabled the msec on the timestamp service(service timestamps log datetime localtime msec) for logs but I don't see the msec on the messages sent to the syslog server.
show logging from the device(msec is working here)
Mar  9 10:12:51: %SPANTREE-6-PORT_STATE: Port Gi1/0/1 instance 0 moving from forwarding to disabled
Mar  9 10:12:51: %SPANTREE-7-PORTDEL_SUCCESS: GigabitEthernet1/0/1 deleted from Vlan 1000
Mar  9 10:12:52: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/1, changed state to down
Mar  9 10:12:53: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/1, changed state to down
Mar  9 10:13:05: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/1, changed state to up
Mar  9 10:13:06: %SPANTREE-6-PORT_STATE: Port Gi1/0/1 instance 0 moving from disabled to blocking
Mar  9 10:13:06: %SPANTREE-6-PORT_STATE: Port Gi1/0/1 instance 0 moving from blocking to forwarding
Mar  9 10:13:06: %SPANTREE-5-TOPOTRAP: Topology Change Trap for instance 0
Mar  9 10:13:07: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/1, changed state to up
Mar  9 10:15:19.947: %PARSER-5-CFGLOG_LOGGEDCMD: User:user  logged command:service timestamps log datetime localtime msec
Mar  9 10:15:21.223: %SYS-5-CONFIG_I: Configured from console by user on vty1 (10.110.253.126)
Mar  9 10:15:36.466: %SPANTREE-7-PORTDEL_SUCCESS: GigabitEthernet1/0/1 deleted from Vlan 1
Mar  9 10:15:36.466: %SPANTREE-7-PORTDEL_SUCCESS: GigabitEthernet1/0/1 deleted from Vlan 201
Mar  9 10:15:36.466: %SPANTREE-7-PORTDEL_SUCCESS: GigabitEthernet1/0/1 deleted from Vlan 300
Mar  9 10:15:36.466: %SPANTREE-7-PORTDEL_SUCCESS: GigabitEthernet1/0/1 deleted from Vlan 304
Mar  9 10:15:36.466: %SPANTREE-7-PORTDEL_SUCCESS: GigabitEthernet1/0/1 deleted from Vlan 309
Mar  9 10:15:36.466: %SPANTREE-7-PORTDEL_SUCCESS: GigabitEthernet1/0/1 deleted from Vlan 312
Mar  9 10:15:36.466: %SPANTREE-7-PORTDEL_SUCCESS: GigabitEthernet1/0/1 deleted from Vlan 320
Mar  9 10:15:36.466: %SPANTREE-7-PORTDEL_SUCCESS: GigabitEthernet1/0/1 deleted from Vlan 331
Mar  9 10:15:36.466: %SPANTREE-7-PORTDEL_SUCCESS: GigabitEthernet1/0/1 deleted from Vlan 332
Mar  9 10:15:36.466: %SPANTREE-7-PORTDEL_SUCCESS: GigabitEthernet1/0/1 deleted from Vlan 360
Mar  9 10:15:36.466: %SPANTREE-7-PORTDEL_SUCCESS: GigabitEthernet1/0/1 deleted from Vlan 800
Mar  9 10:15:36.470: %SPANTREE-7-PORTDEL_SUCCESS: GigabitEthernet1/0/1 deleted from Vlan 801
Mar  9 10:15:36.470: %SPANTREE-7-PORTDEL_SUCCESS: GigabitEthernet1/0/1 deleted from Vlan 900
Mar  9 10:15:36.470: %SPANTREE-6-PORT_STATE: Port Gi1/0/1 instance 0 moving from forwarding to disabled
Mar  9 10:15:36.470: %SPANTREE-7-PORTDEL_SUCCESS: GigabitEthernet1/0/1 deleted from Vlan 1000
Mar  9 10:15:37.459: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/1, changed state to down
Mar  9 10:15:38.476: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/1, changed state to down
Mar  9 10:15:46.176: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/1, changed state to up
Mar  9 10:15:47.193: %SPANTREE-6-PORT_STATE: Port Gi1/0/1 instance 0 moving from disabled to blocking
Mar  9 10:15:47.214: %SPANTREE-6-PORT_STATE: Port Gi1/0/1 instance 0 moving from blocking to forwarding
Mar  9 10:15:47.225: %SPANTREE-5-TOPOTRAP: Topology Change Trap for instance 0
Mar  9 10:15:48.197: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/1, changed state to up
Logs sent to the syslog server:
<190>Mar 9 10:15:47 10.50.20.10 %SPANTREE-6-PORT_STATE: Port Gi1/0/1 instance 0 moving from blocking to forwarding
Without the msec value ^
rasmus.elmholt
Level 7
Level 7
Doing some packet capture on a firewall the syslog messages are going through I can see that the msec is in the syslog packages. So it must be the splunk service not showing it.
#show loggin(on device)
Mar 14 09:45:10.430: %SPANTREE-6-PORT_STATE: Port Gi1/0/1 instance 0 moving from blocking to forwarding
# syslog packet information
<190>1005: Mar 14 09:45:10.430: %SPANTREE-6-PORT_STATE: Port Gi1/0/1 instance 0 moving from blocking to forwarding
#Splunk data:
<190>Mar 14 09:45:10 10.50.20.10 %SPANTREE-6-PORT_STATE: Port Gi1/0/1 instance 0 moving from blocking to forwarding
6 Replies 6
balaji.bandi
Can you post syslog config from switch and give us what syslog you using.
I use Cisco Cat 9300 switches and Graylog - I see the below message on Graylog : (is this what you looking ?)
<189>11762: SW01: ]: Oct 19 15:46:15.776 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5, changed state to up
BB
We are using splunk. I will have to look into why the value is not shown correct. But I would get the thing I see in splunk is exactly to same as the switch will send.
The configuration is something like this:
logging trap debugging
logging host 8.8.8.8
spanning-tree logging
logging buffered 65535
service timestamps debug datetime localtime
service timestamps log datetime msec localtime
please try below config,
service timestamps debug uptime
service timestamps debug datetime msec show-timezone
service timestamps debug datetime msec show-timezone localtime
service timestamps log uptime
service timestamps log datetime msec show-timezone
service timestamps log datetime msec show-timezone localtime
I cannot see how those commands would help as they are just overwriting eachother.
rasmus.elmholt
Level 7
Level 7
#Splunk data:
