MSFC card is not showing
Shahab Khan
Hi All,
One of our client is having Cisco 6513 with SUP720-3B. Currently they are running with CatOS version 8.5.2. Now we are planning to upgrade it to IOS. Though SUP720-3B comes with MSFC card, but in this case I am not seeing MSFC card in either show version nor in show module.
So, my query is how can we troubleshoot in CatOS to identify whether the MSFC card is faulty or not.
Shahab
6 Replies 6
InayathUlla Sharieff
Shahab,
Can you post output of show module.
Also try the following command:
Catos> Session X (X- should be replaced with the number of sup module number.
Example:
If the sup module is install;ed on slot 5 then:
cat6k(enable)Show module
Mod Slot Ports Module-Type               Model               Sub Status
5   5    9     1000BaseX Supervisor      WS-SUP32-GE-3B      yes ok
15  5    1     Multilayer Switch Feature WS-F6K-MSFC2A       no  ok
Cat6k>session 15
Inayath
InayathUlla,
Here is the show module output.
Mod Port Model               Serial #    Versions
1   48   WS-X6548-GE-TX               Hw : 10.1
                                         Fw : 7.2(1)
                                         Sw : 8.5(2)
2   48   WS-X6548-GE-TX               Hw : 10.1
                                         Fw : 7.2(1)
                                         Sw : 8.5(2)
3   48   WS-X6548-GE-TX                   Hw : 10.1
                                         Fw : 7.2(1)
                                         Sw : 8.5(2)
4   48   WS-X6548-GE-TX               Hw : 10.1
                                         Fw : 7.2(1)
                                         Sw : 8.5(2)
5   48   WS-X6548-GE-45AF             Hw : 12.6
                                         Fw : 7.2(1)
                                         Sw : 8.5(2)
6   48   WS-X6548-GE-TX               Hw : 10.1
                                         Fw : 7.2(1)
                                         Sw : 8.5(2)
7   2    WS-SUP720-3B                 Hw : 4.7
                                         Fw : 8.5(4)
                                         Fw1: 8.5(2)
                                         Sw : 8.5(2)
                                         Sw1: 8.5(2)
         WS-F6K-PFC3B                 Hw : 2.5
                                         Sw :
8   48   WS-X6548-GE-TX               Hw : 10.1
                                         Fw : 7.2(1)
                                         Sw : 8.5(2)
9   48   WS-X6548-GE-TX               Hw : 10.1
                                         Fw : 7.2(1)
                                         Sw : 8.5(2)
10  48   WS-X6548-GE-TX               Hw : 10.1
                                         Fw : 7.2(1)
                                         Sw : 8.5(2)
11  48   WS-X6548-GE-45AF             Hw : 12.6
                                         Fw : 7.2(1)
                                         Sw : 8.5(2)
12  48   WS-X6548-GE-TX               Hw : 10.1
                                         Fw : 7.2(1)
                                         Sw : 8.5(2)
13  48   WS-X6548-GE-TX               Hw : 10.1
                                         Fw : 7.2(1)
                                         Sw : 8.5(2)
Shahab
Sorry I the above output is of show version. Below is the show module output.
1   1    48    10/100/1000BaseT Ethernet WS-X6548-GE-TX      yes ok
2   2    48    10/100/1000BaseT Ethernet WS-X6548-GE-TX      yes ok
3   3    48    10/100/1000BaseT Ethernet WS-X6548-GE-TX      yes ok
4   4    48    10/100/1000BaseT Ethernet WS-X6548-GE-TX      yes ok
5   5    48    10/100/1000BaseT Ethernet WS-X6548-GE-45AF    yes ok
6   6    48    10/100/1000BaseT Ethernet WS-X6548-GE-TX      yes ok
7   7    2     1000BaseX Supervisor      WS-SUP720-3B        yes ok
8   8    48    10/100/1000BaseT Ethernet WS-X6548-GE-TX      yes ok
9   9    48    10/100/1000BaseT Ethernet WS-X6548-GE-TX      yes ok
10  10   48    10/100/1000BaseT Ethernet WS-X6548-GE-TX      yes ok
11  11   48    10/100/1000BaseT Ethernet WS-X6548-GE-45AF    yes ok
12  12   48    10/100/1000BaseT Ethernet WS-X6548-GE-TX      yes ok
13  13   48    10/100/1000BaseT Ethernet WS-X6548-GE-TX      yes ok
While giving Catos> Session 15, I am getting the error "module 15 is not installed"
Note:
In certain circumstances, the MSFC is not displayed when you issue the commands that this document shows. If the MSFC does not display in the output when you issue the commands, but you are certain that a routing engine exists on the Supervisor Engine module, you need to recover the MSFC. For the recovery method, refer to the document
Recover an MSFC Missing from the Supervisor Engine show module Command
Inayath
Is this recovery method is for CatOS or IOS?
catos
