GLC-SX-MM & GLC-SX-MMD SFP cards
lerner cisco
I would like to know GLC-SX-MM and GLC-SX-MMD can be used to connect between two switches are these SFP compatible each other to form trunk
I have core switch with existing  GLC-SX-MM SFP transciver , I am ordering new switch with SFP   GLC-SX-MMD   as cisco announced end of sale GLC-SX-MM SFP , would like to know one end is GLC-SX-MM and other end GLC-SX-MMD   com[atiable ???
SW1 < --------------------------------------------------------------------------> SW2
GLC-SX-MM                   trunk                                             GLC-SX-MMD
2 Accepted Solutions
aukhadiev
Yes, of course, they can interact with each other...
GLC-SX-MMD is the same 1000BASE-SX SFP transceiver module (MMF, 850nm) as the GLC-SX-MM.
The only difference is the presence of future DOM (Digiatal Optical Monitoring) in GLC-SX-MMD...
InayathUlla Sharieff
GLC-SX-MMD=
1000BASE-SX SFP transceiver module for MMF, 850-nm wavelength, extended operating temperature range and DOM support, dual LC/PC connector
GLC-SX-MM=
1000BASE-SX SFP transceiver module for MMF, 850-nm wavelength, dual LC/PC connector
Yes they are compatible between each other.
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6981.html
Inayath
aukhadiev
GLC-SX-MMD=
GLC-SX-MM=
Inayath
