mst vlans issue
tferg155
hello everyone
I have a problem and i hope to find the solution here so i have a lab with 3 switches 1 core and 2 aggr all the switches are linked together using etherchannel and MSTP
all the switches have hosts on valns 10 20 30 40 50 60
all the informations are below in the config
MY PROBLEM IS WHY SWITCH 3 IS BLOKING THE VLAN
hosts int switch 1 and 2 can reach each other and also can reach switch 3 but SWITCH CAN NOT REACH ANY OF THEM
I WILL BE HAPPY IF SOMEONE GIVE THE SOLUTION
this is the diagram
SWITCH 1CORE CONFIG
S1(config)#do sh run
Building configuration...
Current configuration : 3153 bytes
! Last configuration change at 02:42:14 UTC Tue Sep 14 2021
version 15.1
service compress-config
hostname S1
boot-start-marker
boot-end-marker
logging discriminator EXCESS severity drops 6 msg-body drops EXCESSCOLL
logging buffered 50000
logging console discriminator EXCESS
no aaa new-model
no ipv6 cef
ipv6 multicast rpf use-bgp
no ip icmp rate-limit unreachable
no ip domain-lookup
ip cef
spanning-tree mode mst
spanning-tree mst configuration
name INE
revision 6767
instance 1 vlan 10, 20
instance 2 vlan 30, 40
instance 3 vlan 50, 60
spanning-tree mst 1-3 priority 24576
vlan internal allocation policy ascending
ip tcp synwait-time 5
interface Port-channel1
switchport
switchport mode trunk
interface Port-channel2
switchport
interface Ethernet0/0
duplex auto
interface Ethernet0/1
duplex auto
channel-protocol pagp
channel-group 2 mode desirable
interface Ethernet0/2
duplex auto
channel-group 1 mode desirable
interface Ethernet0/3
duplex auto
interface Ethernet1/0
duplex auto
interface Ethernet1/1
duplex auto
interface Ethernet1/2
duplex auto
interface Ethernet1/3
duplex auto
interface Ethernet2/0
duplex auto
interface Ethernet2/1
duplex auto
interface Ethernet2/2
switchport access vlan 10
switchport mode access
duplex auto
spanning-tree portfast
interface Ethernet2/3
switchport access vlan 20
duplex auto
interface Ethernet3/0
switchport access vlan 30
duplex auto
interface Ethernet3/1
switchport access vlan 40
duplex auto
interface Ethernet3/2
switchport access vlan 50
duplex auto
interface Ethernet3/3
switchport access vlan 60
duplex auto
interface Vlan1
no ip address
shutdown
interface Vlan10
ip address 192.168.10.1 255.255.255.0
interface Vlan20
ip address 192.168.20.1 255.255.255.0
interface Vlan30
ip address 192.168.30.1 255.255.255.0
interface Vlan40
ip address 192.168.40.1 255.255.255.0
interface Vlan50
ip address 192.168.50.1 255.255.255.0
interface Vlan60
ip address 192.168.60.1 255.255.255.0
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
SWITCH 2 CONFIG
S2(config)#do sh run
Current configuration : 2972 bytes
! Last configuration change at 02:42:10 UTC Tue Sep 14 2021
version 15.1
hostname S2
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
no ip domain-lookup
ip cef
name INE
revision 6767
spanning-tree mst 1-3 priority 28672
vlan 10
name IT
vlan 20
name PR
vlan 30
name HR
vlan 40
name SLAES
vlan 50
name SUPPORT
vlan 60
name SOCIAL
interface Port-channel3
switchport
switchport
duplex auto
channel-group 3 mode desirable
duplex auto
duplex auto
duplex auto
duplex auto
duplex auto
duplex auto
duplex auto
duplex auto
duplex auto
duplex auto
duplex auto
duplex auto
duplex auto
duplex auto
duplex auto
interface Vlan1
no ip address
shutdown
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
SWITCH 3 CONFIG
S3(config-if)#do sh run
Current configuration : 2935 bytes
! Last configuration change at 02:42:06 UTC Tue Sep 14 2021
version 15.1
hostname S3
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
no ip domain-lookup
ip cef
name INE
revision 6767
vlan 10
name IT
vlan 20
name PR
vlan 30
name HR
vlan 40
name SLAES
vlan 50
name SUPPORT
vlan 60
name SOCIAL
switchport
switchport
duplex auto
duplex auto
duplex auto
duplex auto
duplex auto
duplex auto
duplex auto
duplex auto
duplex auto
duplex auto
duplex auto
duplex auto
duplex auto
duplex auto
duplex auto
duplex auto
interface Vlan1
no ip address
shutdown
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
15 Replies 15
its a huge lab i need help just with this part
