Multi VLAN streams output through single PORT/ VLAN ?
encapsulation1
here is the scenario;
i have a 3560 switch which i use as videoswitch i have 5 channels coming from 5 different encoders via 172.x.x.x, all of these 5 channels connect from video switch(3560 to Prostream 1000 then further to uplink;
I have created 5 differnet vlans for each channel but i am having problem going out on a sigle port to connet to prostream 1000, i have tried trunk and via ip route defaut getaway but no luck so far.
Can someone out there tell me how can i manage to put all five stream (coz they are video streams) from five differnet vlan to go out on a single port to connect to ProStream which is also IP in.
no aaa new-model
system mtu routing 1500
vtp mode transparent
ip subnet-zero
ip routing
ip dhcp snooping vlan 10-50
ip dhcp snooping
ip igmp snooping querier
no file verify auto
spanning-tree mode rapid-pvst
vlan internal allocation policy ascending
vlan 10
 name CH1
vlan 20
 name CH2
vlan 30
 name CH3
vlan 40
 name CH4
vlan 50
 name CH5
interface GigabitEthernet0/1
 description PROSTREAM_INTERFACE
 switchport mode trunk
interface GigabitEthernet0/2
 description PROSTREAM_BACKUP_PORT
 no switchport
 ip address dhcp
interface GigabitEthernet0/3
 description CH1
 switchport access vlan 10
 switchport mode access
 spanning-tree portfast
interface GigabitEthernet0/4
 description CH1
interface GigabitEthernet0/5
 description CH2
 switchport access vlan 20
interface GigabitEthernet0/6
 description CH2
interface GigabitEthernet0/7
 description CH3
 switchport access vlan 30
interface GigabitEthernet0/8
 description CH3
interface GigabitEthernet0/9
 description CH4
 switchport access vlan 40
interface GigabitEthernet0/10
 description CH4
interface GigabitEthernet0/11
 description CH5
 switchport access vlan 50
interface GigabitEthernet0/12
 description CH5
interface GigabitEthernet0/24
 no switchport
 ip address 192.168.0.153 255.255.255.0
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface GigabitEthernet0/27
interface GigabitEthernet0/28
interface Vlan1
 no ip address
 shutdown
interface Vlan10
 description
 ip address 172.16.0.1 255.255.255.0
interface Vlan20
 description
 ip address 172.17.0.1 255.255.255.0
interface Vlan30
 description
 ip address 172.18.0.1 255.255.255.0
interface Vlan40
 description
 ip address 172.19.0.1 255.255.255.0
interface Vlan50
 description I
 ip address dhcp
ip default-gateway 172.15.0.1
ip classless
ip route 0.0.0.0 0.0.0.0 172.15.0.1
ip route 172.15.0.0 255.255.0.0 172.15.0.1
ip http server
control-plane
banner motd ^C
line con 0
 exec-timeout 0 0
 password 123
 logging synchronous
line vty 0 4
 password 123
 login
line vty 5 10
 password 123
 login
line vty 11 15
 login
end
thanks
Reza Sharifi
Its confusing, because you have port g0/1 configured as trunk, but than you have all the SVIs on the switch.  You also have a default-gateway command and a default route command.  If the switch is layer-2 only than you only need a default-gateway.  If the switch is layer-3 with SVIs than you need a default route only.
Is the ProStream 1000 connected to another switch/router besides the 3560 switch?
Are you trying to use the switch to route between your vlans?
Can you provide a diagram of your network?
Also, what is the IP segment for vlan 50?
Reza Sharifi
It is a bit confusing maybe and it is because im new to cisco switching world.
Switch is 3560 and it is layer3,
Reza, picture this:
vlan10 (port2) ip-in from DVBT encoder ip 172.16.0.10 255.255.255.0 ip socket out 239.0.0.3
vlan20 (port4) ip-in from DVBT2 encoder IP 172.17.0.10 255.255.255.0 ip socket out 239.0.0.4
and so with other 3 vlans
g0/1 has to be the port the streams out all these SVIs to ProStream IP 172.15.0.10
( now i have a config file of the same switch but i only has one vlan and streams multicast to all ports and i want to prevent that, the old config file is attached)
