Multicast Does not work between different VLANS
runinorte
I have problems with multicast. On the same VLAN i can see the SAP announcement in VLC and play, but on different VLAN i can see SAP but i cant play it. The play turn to pause and the video doesn´t appear.
I have 2 Cisco 6500 switch CORE with GLBP configured but not working. In the second switch i have all interfaces in shutdown. The first core switch have L3 routing enable.
The Global configurations:
ip multicast-routing.
I have the transmitter PC on vlan 51 i transmit to 230.0.0.50 group an im trying to recive on vlan 80. The vlans configurations are:
Vlan 51
ip address x.x.31.254 255.255.255.0
ip pim sparse-dense-mode
Vlan 80
ip address x.x.80.1 255.255.255.0
I have 2 Cisco 2960 (L2 only) for the access.
The principal commands outputs are:
CORE1#show ip mroute | inc 230.0.0.50
(*, 230.0.0.50), 01:50:50/00:02:21, RP 0.0.0.0, flags: DC
CORE1#
CORE 1
interface Vlan1
ip address x.x.1.1 255.255.0.0
ip access-group 101 out
no ip unreachables
mls rp ip
interface Vlan51
ip access-group 151 out
ip helper-address x.x.x.x
no ip unreachables
mls rp ip
interface Vlan80
ip access-group 150 out
no ip unreachables
glbp 80 ip x.x.80.254
glbp 80 timers 5 18
glbp 80 timers redirect 600 7200
glbp 80 priority 254
glbp 80 preempt delay minimum 60
glbp 80 authentication text glbpkey
glbp 80 forwarder preempt delay minimum 60
CORE2
interface Vlan1
ip address x.x.1.4 255.255.0.0
no ip unreachables
mls rp ip
interface Vlan51
ip address x.x.31.2 255.255.255.0
no ip unreachables
shutdown
mls rp ip
glbp 51 ip x.x.31.254
glbp 51 timers 5 18
glbp 51 timers redirect 600 7200
glbp 51 preempt delay minimum 60
glbp 51 authentication text glbpkey
glbp 51 forwarder preempt delay minimum 60
interface Vlan80
ip address x.x.80.2 255.255.255.0
no ip unreachables
shutdown
mls rp ip
glbp 80 timers 5 18
end
Someone can help?
Alfredo
18 Replies 18
Hi Jon, now i revert back to dense mode all interfaces.
This is the output for the show ip mroute associate with the multicast stream.
(*, 230.0.0.50), 00:16:21/00:02:43, RP 0.0.0.0, flags: DC
  Incoming interface: Null, RPF nbr 0.0.0.0
  Outgoing interface list:
    Vlan80, Forward/Sparse, 00:16:21/00:02:43
    Vlan254, Forward/Sparse-Dense, 00:16:21/00:00:00
I stop all the VLC receivers on vlan 80 an try to connect again but not work.
What client are you using? Windows 7 or XP? Check for client firewall issues and client/server mtu issues. What is the output of the show ip mroute active command when the server  is sending the stream?  On the 2960 switches the client is connected to what is the ouput of the show ip igmp snoooping groups?
**Please rate posts you find helpful**
Hi johnd...
Im using VLC 1.1.2 (i can not update because i have a DVDT2 card to capture the digital terrestrial television and it only work in this version). I have all the firewalls down.
This is the output for the show ip igmp snooping groups on the 2960.
80        230.0.0.50               igmp        v2          Gi1/0/21, Gi1/0/24
Port G1/0/21 is where the receiver is conected and the 24port is the trunk.
Jon, i revert and this is the output. I put the ip pim rp-address the same of the lookpback that i create previously.
(*, 230.0.0.50), 00:37:46/00:02:19, RP 192.168.230.230, flags: SJC
    Vlan80, Forward/Dense, 00:09:52/00:00:00
The strange thing is that I have more than 40 vlans and it only fail in some vlans like 80.
Okay, lets try and break this down logically.
1) pick a vlan where it does work and use vlan 80 for one that doesn't
2) describe exactly where the source of the stream and the client of the stream are for both scenarios. What i mean by this is which switch is the source/client connected to and how is this switch connected back to the core. So for both scenarios ie. one that works and vlan 80 we need the full path in terms of switches etc. between the source and client.
3) post the L3 SVI configs for source/client vlans from the core switches
Jon
