02-07-2011 11:15 AM - edited 03-06-2019 03:24 PM
I configured Etherchannel between 3 ports on server and on Cat 6500 VSS, two ports on one physical chassis, and one port on another.
If I look at etherchannel status, I see no errors.
I used port-channel load-balance src-mac as LB algorithm, since most of the servers accessing that server are on the same LAN, so their MAC addresses should be visible to the switch.
As a guide-line I used this document:
The problem is that LB is not working! At all!!!
We tested with copying multiple files from/to that server, to/from multiple servers on the same LAN segment, and we always see just one NIC used for TX traffic (NIC 1), and NIC 3 is used for RX traffic (practically, switch is forwarding all traffic through one interface). And we hit 92% of utilization on the link not even then next flow didn’t go through other etherchannel links.
Is there any issue with our setup?
Mile
02-07-2011 11:44 AM
what's the server on the other side ? Linux , windows etc . I configured server bonding on CentOS few days back ( using a totally different switch -- no cisco ) , it wasn't working and was showing the same symtoms. I ended up using LACP on the switch side with src/dest mac hashing and bond mode 802.3ad on the Centos side. It was only then it started load balancing traffic across four links in tha Bond.
Manish
02-07-2011 11:58 AM
It is Windows 200x servers... We tried that on 2 different HP servers. But it's windows either way.
We also tried LACP and no negotiations, the results were the same.
02-07-2011 12:13 PM
