Multilayer Switch troubleshooting
mazharsaeedms1
Community Member
I have two network 131.107.X.X/16 and 172.25.29.232/29, I want to communicate both network with each other, please need your suggestion.
Attach snap topology is given. without any changes in topology, how communication is possible??
10 Replies 10
Ganesh Hariharan
Hello ,
Create trunk between 2960 and 3560 switch allowing network A VLAN and create an SVI for network A in 3560 switch which would be the gateway for all host in network A.
Create a Point to point link between router and 3560 over /30 subnet for static routing or if you want to do via dynamic that can be also done.
Lets suppose you choose static then put a static route towards 3560 interface which is directly connected via router and in 3560 drop a default route toward router interface.
By doing above you have connectivity between networks.
Hope it Helps..
-GI
Rate if it Helpss
Hi Ganesh Hariharan,
Please look into running config of Cisco 2960 switch and Multilayer switch 3560:
2960:
interface FastEthernet0/1
switchport trunk allowed vlan 3,12
switchport mode trunk
interface FastEthernet0/2
switchport access vlan 3
switchport mode access
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
3560
switchport access vlan 12
tx-ring-limit 3
interface Vlan3
ip address 131.107.0.1 255.255.0.0
interface Vlan12
ip address 172.25.29.237 255.255.255.248
819 HGW Router:
interface GigabitEthernet0
duplex auto
speed auto
After configuration i cant ping both PCs from network A to Network B
Hello ,
You have same ip address configured on VLAN 12 on L3 switch and on router interface Gig0.
Change the ip address at router level to 172.25.29.238 255.255.255.248 and configure a route in router for VLAN 3 subnet 131.107.0.1/24 towards 172.25.29.237.
and in L3 switch configure a default route 0.0.0.0/0 172.25.29.238 255.255.255.248
Hope it Helps..
-GI
Rate if it Helps..
after changes same result.
Are you able to ping router interface from 3560 switch ?
and could you please share the show run in 3560 and in router .
-GI
sure have look Router & MLS 3560 Running Configuration:
C819HGW:
ip dhcp excluded-address 10.10.10.1
ip dhcp pool ccp-pool
network 10.10.10.0 255.255.255.248
default-router 10.10.10.1
spanning-tree mode pvst
ip address 172.25.29.238 255.255.255.248
duplex auto
speed auto
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
interface wlan-ap0
description Service module interface to manage the embedded AP
ip unnumbered Vlan1
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
ip address 10.10.10.1 255.255.255.248
router eigrp 100
network 172.25.0.0
network 131.107.0.0
no auto-summary
ip route 0.0.0.0 0.0.0.0 FastEthernet0
MLS 3560:
interface Vlan3
interface Vlan12
router eigrp 100
network 172.25.0.0
network 131.107.0.0
no auto-summary
ip route 0.0.0.0 0.0.0.0 172.25.29.238
can you please assist me through email, i have sent Packet tracer file to you for better understand what i want, because in my real scenario is same as I depict in this topology. please share your email address.
Can you attach the pkt tracer file to this post?
  What interfaces are you using to connect between the 3560 and router ?   You will need to connect those 2 devices with a link using a /30 subnet .  I don't see that in your  configs .  and then create statics pointing to each others subnets across that link unless you are using routing protocols between the 3560 and the router .  Also you really don't need any kind of trunking between the 2960 and the 3560 seeing it's a single subnet  it can be made an access port in vlan 3  on both sides .
please find attach file
The concept is to configure:
A- Inter-VLAN routing.
B- SVI.
Ref:
http://www.cisco.com/c/en/us/support/docs/lan-switching/inter-vlan-routing/41860-howto-L3-intervlanrouting.html
http://www.cisco.com/c/en/us/support/docs/lan-switching/inter-vlan-routing/14976-50.html
hope it helps,
Aus
