Multiple VLAN extension from Nexus7k to ASR 1004
Rahul Dahiya
We bought a pair of ASR 1004 to be installed at Primar & Secondary data center and one thing is to run OTV over it, but to do that, I have to extend multiple VLANs from my Core (Pair of Nexus 7010s) connected directly to the ASR is Primary Data center, I looked at some documents but didn't get a good idea about it, can anyone help me to know how we can extend multiple VLANs from Nexus switch to an ASR.
subinterfaces on the ASR equate to trunked vlans on a physical interface on 7k.
can you provide a bit more info about what you might need help with ?
I was looking at the configuration on ASR end when you extend multiple VLANs from a swtich to the ASR and hopefully that is done using "service instances". I have not implemented that yet, so just seeking advice from someone how does.
