10-14-2021 01:01 AM
Hi all,
I got issue with customer that stated with STP issue. I'm not sure what is the root cause of this since the log is already 2 months ago
The log shows the HSRP priority protocol also has been changed and STP port state also not stable. does the interface having issue?
I attached the log files.
Appreciate if anyone can give advise.
Hafiz,
thanks
Solved! Go to Solution.
10-14-2021 01:59 AM
- As you say these events are difficult to correlate to current problem conditions if any. Saw what seemed to be a loop on 18-aug , but the main thing is , if the customer is still experiencing these problems, then provide log entries as of 'today' (so to speak).
M.
10-14-2021 01:59 AM
M.
