N7K replacement
Redbeanie
Community Member
We are looking for recommendations for replacing our existing N7K.
Is someone able to guide us in the right direction...
This is the current build:
Mod  Ports  Module-Type                         Model              Status
1    48     1/10 Gbps BASE-T Ethernet Module    N7K-F248XT-25E     ok
2    48     1/10 Gbps BASE-T Ethernet Module    N7K-F248XT-25E     ok
3    48     1/10 Gbps BASE-T Ethernet Module    N7K-F248XT-25E     ok
4    48     1/10 Gbps BASE-T Ethernet Module    N7K-F248XT-25E     ok
5    0      Supervisor Module-2                 N7K-SUP2E          active *
6    0      Supervisor Module-2                 N7K-SUP2E          ha-standby
7    48     1/10 Gbps Ethernet Module           N7K-F248XP-25E     ok
Many thanks
7 Replies 7
Mark Elsen
       - FYI : https://www.cisco.com/c/en/us/products/switches/switch-selector.html?guide=data_center|lantype|lanupgrade|nexus_7000#~select-switch
                      Scroll down too!
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Reza Sharifi
The 9400 should be a good replacement for the 7K, since you only need Ethernet modules. See datasheet:
https://www.cisco.com/site/us/en/products/networking/switches/catalyst-9400-series-switches/index.html
balaji.bandi
Recently replaced Nexus 7K with Nexus 9K spine and Leaf (that is best option you have)
which support vPC, if you going nexus9K model (VDC support) - you do not need, you can segment the network different.
check some white papers :
https://www.cisco.com/c/en/us/td/docs/dcn/whitepapers/migrating-classic-ethernet-to-vxlan-bgp-evpn-white-paper.html#Introduction
BB
kewwa
Level 2
Level 2
I actually need VDC and that is why I was asking about it
For historical reasons I need to segment in a certain way and VRFs are not enough
then look for chasis :
https://www.cisco.com/site/uk/en/products/networking/cloud-networking-switches/nexus-9000-switches/index.html
BB
kewwa
Level 2
Level 2
Why doesn't Cisco want to introduce this feature to N9K?
