10-11-2011 03:57 PM - edited 03-07-2019 02:44 AM
Dear N7K expert,
We are using N7K switch in our lab for performance testing, I have a issue that I couldn't figure out why, hope someone can help.
Basically I found sometimes when I configure a port as trunked port, then add vlans to this port, but it seems that port still doesn't belongs to those vlan if I use "show vlan id xx". I'm using 5.1.5 software release, here's my config and command output:
Demo-7K# show run int eth 9/18
!Command: show running-config interface Ethernet9/18
!Time: Wed Oct 12 04:34:40 2011
version 5.1(5)
switchport mode trunk
switchport trunk allowed vlan 163,203
spanning-tree bpdufilter enable
no shutdown
Demo-7K#
Demo-7K#
Demo-7K# show vlan id 163
VLAN Name Status Ports
163 VLAN0163 active Eth3/16, Eth3/32, Eth3/33
Eth3/34, Eth3/35, Eth9/16
Eth10/1, Eth10/21 ----------------------> interface 9/18 is not here
VLAN Type Vlan-mode
163 enet CE
Remote SPAN VLAN
Disabled
Primary Secondary Type Ports
Demo-7K#
Thanks for help
Ning Chen
10-12-2011 11:09 AM
I'm running 5.2.1 and do see my trunks in my 'show vlan id x' output...but check to see if you see those vlans carried on the trunk "show int e9/18 trunk". I know in most IOS switches we don't put trunk links in the 'show vlan' output.
I can't downgrade mine to 5.1.5 right now to see if i see the same behavior as you or not.
Also is that trunk link up and passing traffic?
10-13-2011 12:17 PM
Thanks Chad, yes I can see my other trunked ports in "show vlan id xx", the link is up and doesn't pass any traffic. The strange thing is I have two ports behave like this, and both ports used to work before, and suddently stop passing traffic. Troubleshooting shows they are not belong to any vlans any more.
