N9K-kernel log (KERN-3-system_MSG buffer_info[next_to_clean])
silverdoor12
I'm facing with this LOGS.
%KERN-3-SYSTEM_MSG: [5163xxx0.xxxxxx] buffer_info[next_to_clean] - kernel
%KERN-3-SYSTEM_MSG: [5163xxx0.xxxxxx]   time_stamp
%KERN-3-SYSTEM_MSG: [5163xxx0.xxxxxx]   next_to_watch
%KERN-3-SYSTEM_MSG: [5163xxx0.xxxxxx]   jiffies
%KERN-3-SYSTEM_MSG: [5163xxx0.xxxxxx]   desc.status
%KERN-3-SYSTEM_MSG: [5163xxx0.xxxxxx] igb 0000:0b:00.0: Detected Tx Unit Hang - kernel
%KERN-3-SYSTEM_MSG: [5163xxx0.xxxxxx]   Tx Queue
%KERN-3-SYSTEM_MSG: [5163xxx0.xxxxxx]   TDH
%KERN-3-SYSTEM_MSG: [5163xxx0.xxxxxx]   TDT
%KERN-3-SYSTEM_MSG: [5163xxx0.xxxxxx]   next_to_use
%KERN-3-SYSTEM_MSG: [5163xxx0.xxxxxx]   next_to_clean
%IM-5-IM_INTF_STATE: mgmt0 is DOWN in vdc 1
%IM-5-IM_INTF_STATE: mgmt0 is UP in vdc 1
VERSION : NXOS 9.3(9)
What should I check for this logs??
silverdoor12
It was log about mis-link. (wrong cable to mgmt port)
Thank you
Mark Elsen
 - It's probably a bug ; look at the current software version running on the nexus; upgrade to last advisory release , if applicable ,
 M.
balaji.bandi
is this switch operational and live ?
Try turn off the device and turn on again, and post complete boot logs.
BB
silverdoor12
Thank you
hosttbo
It is now somewhat humorous to me as I once did the same in my office work and all the members in the office were confused that what is wrong with it, lol... but the office cleaning guy got the real solution.
