N9K reserved vlan
Steev112
i want to migrate the vlan from Cat6500 to N9k and currently using vlan from this range "3968 to 4095", and this range already reserved in N9K, my question is can use the same vlan ? if yes.is there any special configuration?
balaji.bandi
yes you can modify the config and use them, but what is the use case, you run out of VLAN ?
BB
Hi Balaji,
because in current C6500 some vlans used from the same range, and i want to migrate the same configuration. in this case what should i do ?
yes make sense your requirement, if not possible to change VLAN when we do cut over to new envirionment,. you need to change reserved VLAN to different VLAN and use them.
BB
