NAM module
rmv72
Level 7
Level 7
Is't possible to install NAM module into Cat650x/760x without shutdown device?
Jon Marshall
Mike
Yes, the 6500 switch supports OIR (Online Insertion & Removal) for all of it's modules which includes the NAM.
Before you do insert it best to check that your are running version of software that supports it. If not it won't bring the switch down just the NAM module will not come up properly.
Jon
Pravin Phadte
Level 9
Level 9
All the Catalyst 6500 series and Catalyst 6000 family switches support hot swapping, which allows you to install, remove, replace, and rearrange modules without turning off the system power.
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/hardware/Config_Notes/78_14487_support_TSD_Island_of_Content_Chapter.html#wp79713
All Catalyst 6500 series switches, Catalyst 6000 series switches, and Cisco 7600 series routers support hot swapping, which allows you to install, remove, replace, and rearrange modules without turning off the system power.
http://www-europe.cisco.com/univercd/cc/td/doc/product/lan/cat6000/mod_icn/nam/nam_3_4/hw_gd/78_16855.htm#wp36309
I would suggest to wait for more exprets comments on this.
regards,
Pravin..
