Naplam Timeout
Rem Markov
Level 5
Level 5
When running naplam and trying to commit_config() i receive the error below:
Need expert advice
Things you might try to fix this:
Adjust the regex pattern to better identify the terminating string. Note, in
many situations the pattern is automatically based on the network device's prompt.
Increase the read_timeout to a larger value.
Now The problem is that the read_timeout is a netmiko arg and not a Naplam one, is there a way to pass this argument via Naplam?
The driver is nxos-ssh
Hey! I will check on the version and currently it is on one slow nxos device.
But we found a solution! Naplam driver has an argument called optional_args and in it we set a dictionary like that:
optional_args {read_time_override : 1000}
balaji.bandi
what napalm version - post the code, is this for one device - list of devices you trying ?
BB
glad all good
BB
