NAT ICMP, possible?
laichenkang
Hi all
I would like to NAT ICMP (ping) packets from source 10.250.1.105 to appear from source 172.29.186.180. I am using Cisco Router 2811. I can't seem to figure this out. Can any kind soul provide some sample config?
Thank you
Jon Marshall
ip nat inside source static 10.250.1.105 172.29.186.180
int fa0/0
ip nat inside
int fa0/1
ip nat outside
where fa0/0 is where the packet with the original src IP arrives and fa0/1 is where it goes out.
This will NAT all traffic for 10.250.1.105 to 172.29.186.180.
If you just want NAT ICMP only
access-list 101 permit icmp host 10.250.1.105 any
ip nat inside source list 101 10.250.1.105 172.29.186.180 route-map NAT
route-map NAT permit 10
match ip address 101
Jon
Jon Marshall
Posted twice by mistake.
Why would you need to use the route-map?
You don't necessarily need it but it does depend on how you want to do the NAT. So if you just want a static translation between 2 IP's
ip nat inside source static 1.1.1.1 2.2.2.2
If you want to qualify the NAT you can either
1) ip nat inside source list 101 interface fa0/1 overload#
ip nat inside source list 101 pool NATPOOL
or
2) you can use a route-map.
I just thought i'd use a route-map :-)
Jon
