NAT Issue
Vikrant Ambhore
Hello All Experts,
We have Cisco 877 w router, I plugged Polycom video Conferencing unit  into Cisco, & gave Static IP 10.10.10.2,  I am able to access this unit on browser by http://10.10.10.2, we have Public Ip address 203.X.X.X as soon someone dial that IP using their VC unit it should rich our internal IP address 10.10.10.2  also should we be able to get to that when we type203.X.X.X,
from out of office, I think issue is in NAT, but I can't understand
Can anyone help me ?
vikrant
comteam#sh run
Building configuration...
Current configuration : 7986 bytes
version 12.4
no service pad
service password-encryption
hostname comteam
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
crypto pki trustpoint TP-self-signed-814900924
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-814900924
 revocation-check none
 rsakeypair TP-self-signed-814900924
crypto pki certificate chain TP-self-signed-814900924
 certificate self-signed 01
  3082024C 308201B5 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 38313439 30303932 34301E17 0D313031 32313230 38323934
  395A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
  532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3831 34393030
  39323430 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
  E9EF51C3 C77CA2DA 2C06B1DD 4099F308 CBBAA8CB 963E1531 E74C5260 DD9ED17E
  7C1FF7F7 624D3C8A 75894902 BBF2B7CF BE3D8386 B8655693 DCA7E7CB C282D672
  8FC4360C EE032BA2 B685627D DE4DFC39 F39F8D65 23EE720D F5BE2297 96BBF6E4
  65F8947A FFBCDEC9 17772266 0105B4D5 1A81796C 10836ADC F6272826 271C29E3
  02030100 01A37630 74300F06 03551D13 0101FF04 05300301 01FF3021 0603551D
  11041A30 18821663 6F6D7465 616D2E79 6F757264 6F6D6169 6E2E636F 6D301F06
  03551D23 04183016 8014F899 77021298 0AD7AB9E 668987B0 2D2810EF BC93301D
  0603551D 0E041604 14F89977 0212980A D7AB9E66 8987B02D 2810EFBC 93300D06
  092A8648 86F70D01 01040500 03818100 2006DF1D 4379C8C3 9A36A316 79A98E01
  B4474F4F 435A0BE2 3B7014D8 6E78176C 2FC623D0 8AD528B3 193ED349 6CC844DD
  DD82F74C D60A0E6B FF7CCA37 DBE7E8FA 32385098 3A94F2B2 BBA04F6C C3AFCA2C
  38CA6741 7E2690D5 BCD31E58 1D7B8638 0007545E 9F11EB3B 72AE0044 A26AC50E
  8D2DF0D3 35EE4C48 B18533C9 3A643261
        quit
dot11 syslog
dot11 ssid comteam
   vlan 1
   authentication open
   authentication key-management wpa
   guest-mode
   wpa-psk ascii 7 XXXXXXXXX
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1 10.10.10.2
ip dhcp pool sdm-pool
   import all
   network 10.10.10.0 255.255.255.0
   default-router 10.10.10.1
   dns-server 10.10.10.1
   lease 0 2
ip domain name yourdomain.com
ip name-server 203.0.178.191
ip name-server 203.215.29.191
username XXXXXXXXX privilege 15 password XXXXXXXXX
archive
 log config
  hidekeys
class-map match-all Streaming-Video
 match access-group 103
class-map match-all video-conf
 match access-group 102
class-map match-all Video-Conf
policy-map qos-policy
 class video-conf
  bandwidth 512
 class class-default
  fair-queue
bridge irb
interface ATM0
 no ip address
 no atm ilmi-keepalive
 dsl operating-mode auto
interface ATM0.1 point-to-point
 pvc 8/35
  pppoe-client dial-pool-number 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
 no ip address
 ip nat inside
 ip virtual-reassembly
 encryption vlan 1 mode ciphers tkip
 ssid comteam
 speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
 54.0
 station-role root
interface Dot11Radio0.1
 encapsulation dot1Q 1 native
 no cdp enable
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 spanning-disabled
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
interface Vlan1
 no ip address
 ip nat inside
 ip tcp adjust-mss 1412
 bridge-group 1
interface Dialer0
 mtu 1454
 ip address negotiated
 ip nat outside
 encapsulation ppp
 ip route-cache flow
 ip tcp adjust-mss 1360
 dialer pool 1
 dialer-group 1
 no cdp enable
 ppp authentication pap callin
 ppp chap refuse
 ppp pap sent-username computerteam password 7 030E71051F0B74696F18
interface BVI1
 ip address 10.10.10.1 255.255.255.0
 ip nat inside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
ip route 0.0.0.0 0.0.0.0 ATM0
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip dns server
ip nat inside source list ToNAT interface Dialer0 overload
ip nat inside source static tcp 10.10.10.2 80 interface Dialer0 80
ip nat inside source static tcp 10.10.10.2 389 interface Dialer0 389
ip nat inside source static tcp 10.10.10.2 1503 interface Dialer0 1503
ip nat inside source static tcp 10.10.10.2 1720 interface Dialer0 1720
ip nat inside source static udp 10.10.10.2 80 interface Dialer0 80
ip nat inside source static udp 10.10.10.2 389 interface Dialer0 389
ip nat inside source static udp 10.10.10.2 1503 interface Dialer0 1503
ip nat inside source static udp 10.10.10.2 1720 interface Dialer0 1720
ip nat inside source static tcp 10.10.10.2 3230 interface Dialer0 3230
ip nat inside source static tcp 10.10.10.2 3231 interface Dialer0 3231
ip nat inside source static tcp 10.10.10.2 3232 interface Dialer0 3232
ip nat inside source static tcp 10.10.10.2 3233 interface Dialer0 3233
ip nat inside source static tcp 10.10.10.2 3234 interface Dialer0 3234
ip nat inside source static tcp 10.10.10.2 3235 interface Dialer0 3235
ip nat inside source static udp 10.10.10.2 3230 interface Dialer0 3230
ip nat inside source static udp 10.10.10.2 3231 interface Dialer0 3231
ip nat inside source static udp 10.10.10.2 3232 interface Dialer0 3232
ip nat inside source static udp 10.10.10.2 3233 interface Dialer0 3233
ip nat inside source static udp 10.10.10.2 3234 interface Dialer0 3234
ip nat inside source static udp 10.10.10.2 3235 interface Dialer0 3235
ip access-list extended ToNAT
 permit ip 10.10.10.0 0.0.0.255 any
no cdp run
control-plane
bridge 1 route ip
line con 0
 password 7 011009094B1E120A33584B08145346445A
 login local
 no modem enable
line aux 0
 login local
line vty 0 4
 access-class 23 in
 privilege level 15
 login local
 transport input telnet ssh
scheduler max-task-time 5000
end
19 Replies 19
there is no trans for port 80..are u sure default gateway on polycom is 10.10.10.1...
do this for troubleshooting:
ip access-list ex 123
10 permit tcp any host <203.x.x.x> eq 80
20 permit tcp any any any eq 80
30 permit ip any any
Then again try accessing port 80 from outside. do a "show access-list 123 " again and see if there are hits for seq 10.Send that output. (you can add similarly other ports as well, but dont forget to add " permit ip any any " in the last line )
Hello Nikita,
I did try but have same issue yet, also i remove ip http server from cisco
comteam#sh ip nat trans
comteam#sh ip nat translations
Pro Inside global      Inside local       Outside local      Outside global
tcp 203.X.X.X.X:80 10.10.10.2:80      ---                ---
udp 203.X.X.X.X:80 10.10.10.2:80      ---                ---
tcp 203.X.X.X.X:389 10.10.10.2:389    ---                ---
udp 203.X.X.X.X:389 10.10.10.2:389    ---                ---
tcp 203.X.X.X.X:1503 10.10.10.2:1503  ---                ---
udp 203.X.X.X.X:1503 10.10.10.2:1503  ---                ---
tcp 203.X.X.X.X:1720 10.10.10.2:1720  ---                ---
udp 203.X.X.X.X:1720 10.10.10.2:1720  ---                ---
tcp 203.X.X.X.X:3230 10.10.10.2:3230  ---                ---
udp 203.X.X.X.X:3230 10.10.10.2:3230  ---                ---
tcp 203.X.X.X.X:3231 10.10.10.2:3231  ---                ---
udp 203.X.X.X.X:3231 10.10.10.2:3231  ---                ---
tcp 203.X.X.X.X:3232 10.10.10.2:3232  ---                ---
udp 203.X.X.X.X:3232 10.10.10.2:3232  ---                ---
tcp 203.X.X.X.X:3233 10.10.10.2:3233  ---                ---
udp 203.X.X.X.X:3233 10.10.10.2:3233  ---                ---
tcp 203.X.X.X.X:3234 10.10.10.2:3234  ---                ---
udp 203.X.X.X.X:3234 10.10.10.2:3234  ---                ---
tcp 203.X.X.X.X:3235 10.10.10.2:3235  ---                ---
udp 203.X.X.X.X:3235 10.10.10.2:3235  ---                ---
tcp 203.X.X.X.X:7735 10.10.10.2:7735  172.22.142.36:3601 172.22.142.36:3601
comteam#sh ip acces
comteam#sh ip access-lists 123
Extended IP access list 123
    10 permit tcp any host 203.X.X.X.X eq www
    20 permit tcp any any eq www
comteam#conf t
forgot to mention, u need to apply the access-list to dia0 interface. ..Makes no sense otherwise.
int dia0
ip access-group 123 in
now try access port 80  and see if there are hits on the access-list
Hi Nikita,
Same Issue Yet, it's strange for me why it's not working on WAN. I am able to access in LAN
FYI,
I has been fix only by ip nat sourse static tcp 10.10.10.2 80 interface Dialer 0 8080
anyway thanks for your Help Nikita, can we communicate in future for cisco Help
