NAT not working between cisco switch C3560E and 1941 k9 Router
Zemede
C3560E cisco switch
my CISCO C3560E switch not working with Router 1941 please can you help me,my configuration as follow
ON ROUTER
G0/0
Ip address DHCP
ip nat outside
No shutdown
G0/10
Ip address 192.168.200.1 255.255 255 252
ip nat inside
No shutdown
Ip route 0.0.0.0 0.0.0.0 dhcp
Ip route 192.168.0.0 255.255.0.0 192.168.200.2
Ip nat inside source list 10 int g0/0 overload
Access-list 10 permit 192.168.0.0 0.0.255.256
ON SWITCH(C3560E with 15.2 IOS version)
Int G0/24
no switchport
Ip address 192.168.200.2 255.255.255.252
No shutdown
Ip route 0.0.0.0.0.0 0.0.0.0 192.168.200.1
7 Replies 7
post the full running configurations of both devices.
What LAN addresses on the switch side do you want to translate ?
What is the purpose of this route ?
--> Ip route 192.168.0.0 255.255.0.0 192.168.200.2
I have Vlan 192.168.1.0/24,192.168.2.0/24,192.168.3.0/24.....192.168.12.0/24 VLANS .,I want to translate internet dhcp public IP to these vlans
Your configuration looks fine except the wildcard mask on the acl ie. you have 0.0.255.256, is that a typo as the last octet should be 255.
Jon
Hello
disable ip routing on the switch
example sw
no ip routing
ip default-gateway 192.168.200.1
nt G0/24
Ip address 192.168.200.2 255.255.255.0
rtr
G0/10
Ip address 192.168.200.1 255.255 255 0
Kind Regards
Paul
Paul
That won't work as he says he has multiple vlans he wants to do NAT for and he must be routing those on the switch.
Jon
How Can VLANs access  internet and communicate each other
Is the acl mask a typo ie. 0.0.255.256 ?
If it is actually 0.0.0.255 in your configuration then post configuration of router.
Jon
