Bookmark
Subscribe
1123
NAT on Cisco Nexus 9504
Muhammad Shoaib
I have a Cisco Nexus Switch and trying to configure NAT for AWS Direct Connect Public Virtual Interface.
Switch : Nexus C9504
Version : 7.0(3)I4(7)
It appears that NAT is not supported on 9500s. Can someone please confirm ?
What are the options if it is not supported ?
Does upgrade solve this problem ?
Thanks in advance.
-mS
Muhammad Awais Khan
Yes it is not supported and it is not the ideal location to do NAT. Where are your internet circuits terminated ? It will be either firewall or Router right ? Ideally, NAT will be either done on the edge device like Router or Firewall which is terminating Internet circuits.
marce1000
 - It seems that NAT should work :
              https://community.cisco.com/t5/switching/nexus-9k-nat-configuration/td-p/3695985
 M.
just to add to the remarks already made, below the link to the guidelines and limitations, where it is stated the NAT is not supported on the 9500 platform:
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/7-x/interfaces/configuration/guide/b_Cisco_Nexus_9000_Series_NX-OS_Interfaces_Configuration_Guide_7x/b_Cisco_Nexus_9000_Series_NX-OS_Interfaces_Configuration_Guide_7x_chapter_0110...
balaji.bandi
Adding to other pots - NAT not supported on N9500.
Most of the Nexus 9500 are design to work with ACI.
BB
