NAT overload problem
garnier.1972
Community Member
I want to Translate all my internal addresses on my WAN cisco's address.
I have followed NAT overload configuration sample in Cisco documentation, but that doesn't work.
No translations are perfomed for my internal adresses.
Could you help me ?
6 Replies 6
jonathanaxford
Level 8
Level 8
Hello there,
It looks like you need to add the IP nat outside and IP nat inside commands to the relevant interfaces...
interface vlan 1
ip nat inside
interface fa0/4
ip nat outside
Give that a try and see what happens...
Cheers
JOnathan
I've added this two statements on my conf (shame on me) but that's doesn't work too.
I've performed a "clear IP nat translation *" an restart a ping from my internal network to a WAN address but that's doesn't work.
I've attached new conf.
Your config should work but try this as well:
ip nat pool test 192.168.2.8 192.168.2.8 netmask 255.255.0.0
no ip nat inside source list 100 interface FastEthernet4 overload
ip nat inside source list 100 pool test overload
regards,
That doesn't work too
But with "no ip cef" in configuration that's work (eiter with interface overload or pool overload) !!!
Why ?
lejoe.thomas
Level 9
Level 9
Hi Garnier,
Please add the following
You need specify nat inside and nat outside interfaces.
int fastethernet4
ip nat outside
int vlan1
ip nat inside
Lejoe
armingojak
Level 2
Level 2
try put "ip nat outside" on WAN interface, and "ip nat inside" on LAN interface...
