NAT port range
CSCO12065472
I would like to forward a range of ports. To test I have setup a Static NAT with a route-map on various devices. However, every time I set it up all ports are forwarded; the route-map never gets consulted. Any advice on how to achieve this would be greatly appreciated.
Please see my lab configuration below:-
R2#sh run
Building configuration...
Current configuration : 1112 bytes
version 12.4
hostname R2
boot-start-marker
boot-end-marker
logging buffered 4096 debugging
no aaa new-model
ip cef
no ip dhcp use vrf connected
ip dhcp pool p1
   network 10.0.0.0 255.255.255.0
   default-router 10.0.0.254
   dns-server 8.8.8.8
no ip domain lookup
username admin privilege 15 password 0 password
bridge irb
interface Loopback1
no ip address
interface FastEthernet0/0
ip address 10.0.0.254 255.255.255.0
ip nat inside
duplex auto
speed auto
interface FastEthernet0/1
ip address 1.1.1.1 255.255.255.0
ip nat outside
duplex auto
speed auto
ip http server
no ip http secure-server
ip nat inside source static 10.0.0.1 1.1.1.1 route-map SNAT extendable
ip access-list extended PORTR
permit tcp any any range 6000 7000
permit udp any any range 9000 10000
route-map SNAT permit 10
match ip address PORTR
control-plane
line con 0
line aux 0
line vty 0 4
privilege level 15
login local
scheduler allocate 20000 1000
end
R2#sh route-map
route-map SNAT, permit, sequence 10
  Match clauses:
    ip address (access-lists): PORTR
  Set clauses:
  Policy routing matches: 0 packets, 0 bytes
R2#sh ip access-list
Extended IP access list PORTR
    10 permit tcp any any range 6000 7000
    20 permit udp any any range 9000 10000
R2#
CSCO12065472
Since postingI have found a workaround. I have given the outside interface a secondary IP address and forwarded all traffic from there. In the real example I have an ACL on the outside interface to block the other ports.
This is the final config:
R2#sh run
version 12.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
ip dhcp pool p1
   dns-server 8.8.8.8
no ip domain lookup
bridge irb
interface Loopback1
no ip address
ip nat inside
duplex auto
speed auto
ip address 1.1.1.2 255.255.255.0  secondary
ip nat outside
duplex auto
speed auto
ip http server
ip nat inside source static 10.0.0.1 1.1.1.2
control-plane
line con 0
line aux 0
line vty 0 4
privilege level 15
login local
end
