Nexus 1000V VEM Error - VUM and Manually - Need Help
martinezaw
Hi All,
I have 4 ESX hosts that I am trying to add to my 1000v VSM. The first two worked using VUM but the second 2 hosts fail. The hosts all appear to be on the same build. I am running ESX 5.0 Update 1. In VUM I get the below error...
Cannot complete a vSphere Distributed Switch operation for one or more host members.
When I try manually I get the below error...
/var/log/vmware # esxcli software vib install -v cross_cisco-vem-v152-4.2.1.2.1.1a.0-3.0.1.vib
[InstallationError]
Error in running mv /tmp/img-stg/data/cisco-ve.v00 /tardisks/:
Return code: 1
Output: mv: cannot rename '/tmp/img-stg/data/cisco-ve.v00': No such file or directory
It is not safe to continue. Please reboot the host immediately to discard the unfinished update.
Please refer to the log file for more details.
Does anyone know what I should do to make this work??
martinezaw
Anybody see this issue before?
I faced this problem today, after reboot the host, the installation worked.
