10-10-2006 05:52 AM - edited 03-05-2019 12:09 PM
You'll have to excuse me, for I'm quite new at this. Our company just purchased an 1811 integrated services router that has two wan ports. I would like to configure the router to support one local LAN subnet with NAT and failover on the two WAN ports. We have SDSL and a T1 for failover. How difficult would this be and where can I look to find out how to configure it? Is it even possible to do via SDM or must it be done via command line?
11-30-2007 08:57 AM
Okay, now I see what you're saying. I may have left these lines out of the sample I attached to my previous post. These lines setup the static NAT for both lines.
ip nat inside source route-map FAST-0 interface FastEthernet0 overload
ip nat inside source route-map FAST-1 interface FastEthernet1 overload
ip nat inside source static 10.0.0.4 Y.Y.Y.Y route-map SERVER-F1
ip nat inside source static 10.0.0.11 Y.Y.Y.Y route-map SERVER-F1
ip nat inside source static 10.0.0.4 X.X.X.X route-map SERVER-F0
ip nat inside source static 10.0.0.11 X.X.X.X route-map SERVER-F0
route-map FAST-1 permit 10
match ip address 150
match interface FastEthernet1
route-map FAST-0 permit 10
match interface FastEthernet0
route-map SERVER-F0 permit 10
match ip address 160
route-map SERVER-F1 permit 10
11-30-2007 09:24 AM
Thanks Steve, that better clarifies what I mean. The routemaps and nat statements should get him going. Also this gives me an idea for a problem I have elsewhere.
Thanks again.
11-30-2007 10:39 AM
Steve hi.
Can you also provide the access lists that relate?
On this case, I remember one of the cisco guys mentioning something about that access-list had to be played around in order to get this done.
11-30-2007 10:56 AM
My access lists are pretty long and specific to my setup. There really isn't much playing that has to be done. Just make sure that each service is represented on the access lists. There should be two separate lists. One that provides access on the FE0 and the other for FE1 so the entries will be the same but with different IP addresses for external.
Aside from that, the access lists are pretty normal.
