NAT rule missing from a running-config
volkovvalery
Hello.
We have Cisco 2851 (c2800nm-adventerprisek9_ivs-mz.124-15.T4).
Periodically the nat rule:
ip nat inside source static ip1 ip2
missing from config.
Why this happens?
6 Replies 6
volkovvalery
Can anybody help me?
does it happen after a reboot ?
No, uptime on my router more than 1 week.
If i replace my rule on
ip nat inside source static tcp ip1 80 ip2 80
It also missing after some hour's of working (frequently this happens in night hour's).
R u using the same IP for multiple translation entries..?
Mahmood
This my config:
ip nat translation tcp-timeout 300
ip nat inside source route-map MAP1 interface GigabitEthernet0/0.123 overload
ip nat inside source static 192.168.0.1 91.196.XX.XX
ip nat inside source static 172.16.0.1 91.196.YY.YY
the latest rule missing
can u remove this line n try.
Mahmood
