Nat with Multilayer switch
davidthang121
Visitor
Hi I am just a starter in CCNA. I want to configure Nat in R1 according to below typology. I do not know how to configure between Multilayer switches that act as a router. I need help. PLEASE help me. I will accept  any suggestions.
8 Replies 8
  NAT is not complicate to setup but you need to know what you want to do with NAT.
The basic config o NAT could look like
On your L3 switch:
interface FastEthernet0/0 (The interface to the router)
ip address x.x.x.x  255.255.255.0 (Use your IP)
ip nat outside
interface FastEthernet0/1 (The interface to the local access switch )
ip address x.x.x.x  255.255.255.0 (Use your IP )
ip nat inside
access-list 1 permit x.x.x.  0.0.0.255  (The network you are assigning to your PCs)
ip nat inside source list 1 interface FastEthernet0/0 overload  (On the interface where you put "ip nat outside")
With that config, all PC from your Lan will get to the routers using the IP address from the interface FastEthernet0/0
Just keep in mind that this is just an example. I did not see your devices and ip address.
Thanks U. Let me explain what my teacher want me to have configure in this scenario. I configure ospf between L3 switch and Router1 (I do include serial link IP address). Default route between Router1 and Router2.
my teacher want me to configure NAT on Router 1 and she want me to think Router 2 as a ISP. I can configure Nat on Router1 but the lan side can not ping with Router 2 because Multilayer switches don't how to get to Router 2. To be able to ping I need to redistribute default route into multilayer switches from ROUTER 1. But I wonder, do I need Nat in this scenario. Without NAT I can ping to Router 2 because I redistribute default route.
Thanks again
Got it. Your teacher probably is trying to simulate what happen on the real world network where the local IP address dont leave to the internet. Then make sense to have a NAT on R1.
On the  R1 interfaces to ISP you use the command "ip nat outside"
On the interface between R1 and and both layer3 switches you add "ip nat inside"
Then, you can create on the R1 the access-list matching the traffic that comes from Core switches.
And lastly you add the NAT statement
You can do a static NAT or you can do overload.  If the assignment did not say which, use
ip nat inside source list 1 interface {here the interface where you added "ip nat outside"}  overload
Try this and if not work, attach you project here. You just need to zip it first.
Let me check
Hello @davidthang121
 Here is the file. Test and let me know.
 Just to show that here it worked, this is the ping to router ISP from PC0
C:\>ping 200.0.0.1
Pinging 200.0.0.1 with 32 bytes of data:
Reply from 200.0.0.1: bytes=32 time=1ms TTL=253
Reply from 200.0.0.1: bytes=32 time=12ms TTL=253
Ping statistics for 200.0.0.1:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 1ms, Maximum = 12ms, Average = 3ms
and here is the NAT happening
R1#sh ip nat translations
Pro Inside global Inside local Outside local Outside global
icmp 200.0.0.2:50 192.168.20.2:50 200.0.0.1:50 200.0.0.1:50
icmp 200.0.0.2:51 192.168.20.2:51 200.0.0.1:51 200.0.0.1:51
icmp 200.0.0.2:52 192.168.20.2:52 200.0.0.1:52 200.0.0.1:52
icmp 200.0.0.2:53 192.168.20.2:53 200.0.0.1:53 200.0.0.1:53
icmp 200.0.0.2:54 192.168.20.2:54 200.0.0.1:54 200.0.0.1:54
icmp 200.0.0.2:55 192.168.20.2:55 200.0.0.1:55 200.0.0.1:55
icmp 200.0.0.2:56 192.168.20.2:56 200.0.0.1:56 200.0.0.1:56
icmp 200.0.0.2:57 192.168.20.2:57 200.0.0.1:57 200.0.0.1:57
Hello
You do not mention what type of switch you are using, I would assume they are not Cat9Ks as such NAT will NOT be supported , in any case based on your topology I would apply your NAT on the rtr.
Example:
conf t
int x/z
description -WAN
ip nat outside
int x/x
description -LAN1
ip nat inside
int x/y
description -LAN2
ip nat inside
Ip route 0.0.0.0 0.0.0.0 interface x/z  200.0.0.1 name default-route-towards-wan
Ip access-list extended NAT
permit ip 192.168.10.0 0.0.0.255 any
permit ip 192.168.20.0 0.0.0.255 any
permit ip 192.168.30.0 0.0.0.255 any
ip nat inside source-list NAT interface x/z
Kind Regards
Paul
Thank you for your answer
My switches doesn't support NAT but the switches are L3. I can configure eigrp and rip but not ospf. Now I wonder, will the switches know how to get to wan router ? If I configure  default route on the router that connects to wan router according to my topology.
Thanks U
But  Can I configure Nat on router.
