NAT with port range
asgerhartmann
Having a 1841 with two interfaces. I need to set up NAT with a range of ports. I already have inside interface and outside interface configured plus i have various static NAT entries with syntax e.g.:
ip nat inside source static 192.168.200.10 4443 87.120.250.47 4443 ext
This works fine and i have 10 static entries in the router by now. Now my newest challenge is to open a port range 50000 to 59999.
Using CLI or Cisco CP i cannot do anything else then mapping one inside port to one outside port.
Do i really have to type in 10000 lines of config? Or is there a way around this?
The best way I would suggest is creat a nat statement with assigning route-map to it like below.
ip nat inside source static 192.168.200.10 87.120.250.47 route-map NAT extendable
access-list 109 permit tcp host 192.168.200.10 range 50000 59999 any
route-map NAT permit 10
match ip address 109
Hope the above will help you.
Please rate the helpfull posts.
Naidu.
5 Replies 5
IAN WHITMORE
Level 4
Level 4
Well, I think the best way is to do a static nat for the IP in question (i.e. all 65535 ports) and then allow the port range in an access-list.
Naidu.
Ok. Thanks for the answers. I will give both above a try and see whats best way forwa
rd.
Well, thanks for the replies. I havent yet deployed this - but will do soon.
Question is now...how do i mark this discussion as "answered"?
BR
Asger
Hi Asger,
You just need to click on the correct answer box which will be there below to this post.
Naidu.
