Native Vlan mistach issue.
mfaccin
Running into an issue with our network stack and Vlan Mismatch.
We have in our environment a mix of ubiquiti and cisco switches. With the current configuration it seems that all the routing is mostly working but we are running into an issue where on two of our cisco switches we are getting a Native vlan mismatch issue. We have two stacks of 2960x's plugged into a ubiquiti aggregation switch via 10gb fiber connection, which then plugs into our Cisco core switch (3560) via a fiber connection as well. Another oddity is that on our second edge stack we will periodically lose connection to it via ssh, while the rest of the hosts that are connected to the switch stay up. We've disabled bpdugaurd on the second edge stack as it wasn't allowing a connection the ubiquiti switch without causing a bpdugaurd error, but we're not sure if that's part of the problem.
On the core and one of the edge stack switches we are getting the following errors:
Edge:  %CDP-4-NATIVE_VLAN_MISMATCH: Native VLAN mismatch discovered on TenGigabitEthernet1/1/4 (3250), with COM4-EDGE03 TenGigabitEthernet1/0/1 (1)
Core:  %CDP-4-NATIVE_VLAN_MISMATCH: Native VLAN mismatch discovered on TenGigabitEthernet2/ 0/1 (3250), with COM4-EDGE03 TenGigabitEthernet1/0/1 (1). (COM3-EDGE01-2).
These errors do not appear on the second edge stack, they only appear on the first edge stack and core switch.
Configurations for each ports as follows:
Edge stack 1:
interface TenGigabitEthernet2/0/1
description Link to Agg
switchport trunk native vlan 3250
switchport trunk allowed vlan 364,380,388,396,464,480,3104,3250
switchport mode trunk
end
Core:
interface TenGigabitEthernet1/1/4
end
Edge stack 2:
interface TenGigabitEthernet1/0/1
description Link to 3rd Floor Agg
spanning-tree bpduguard disable
end
Switched to a different te port and the mismatch issue resolved.
6 Replies 6
In this very rare instance, the error message is pretty descriptive of the issue. It looks like you have a trunk interface configured between the switches with different Native VLANs. By default, Cisco uses VLAN 1 as noted in the error. The other switch is using 3250. It appears the Ubiquiti is using VLAN 1 while you have changed your Cisco devices to use 3250.
To fix this you just need to make them the same. I'm not sure what Ubiquiti uses but to fix the Cisco side you can use the configuration below on the Edge device:
switchport trunk native vlan ### <-- make this the same on both sides. If you only control one side, then just make them match.
Since your edge devices go through the Ubiquiti you need to make sure they match on all P2P interfaces that connect to a switch.
-David
All trunk interfaces should be on native vlan 3250, i have pasted the show ip int output for each of the ports in my post, and they're all on 3250. The Ubiquiti side is also 3250.
krmp010608
Frequent Visitor
Frequent Visitor
You can provide the output of the
  • show interface trunk command from both devices
  • show interface TenGigabitEthernet2/0/1 switchport
  • show interface TenGigabitEthernet1/1/4 switchport
  • show interface TenGigabitEthernet1/1/1 switchport
  • show vlan id 3250
COM3-CORE01#show interface trunk
Port Mode Encapsulation Status Native vlan
Gi1/0/1 on 802.1q trunking 1
Gi1/0/13 on 802.1q trunking 1
Gi1/0/15 on 802.1q trunking 1
Gi1/0/24 on 802.1q trunking 1
Gi1/0/29 on 802.1q trunking 1
Gi1/0/31 on 802.1q trunking 1
Gi1/0/33 on 802.1q trunking 1
Gi1/0/34 on 802.1q trunking 1
Gi1/0/38 on 802.1q trunking 1
Gi1/0/39 on 802.1q trunking 1
Gi1/0/40 on 802.1q trunking 1
Gi1/0/41 on 802.1q trunking 1
Gi1/0/44 on 802.1q trunking 1
Te1/1/4 on 802.1q trunking 3250
Port Vlans allowed on trunk
Gi1/0/1 1,20,3400
Gi1/0/13 1-4094
Gi1/0/15 1-4094
Gi1/0/24 1-4094
Gi1/0/29 1-4094
Gi1/0/31 1-4094
Gi1/0/33 1-4094
Gi1/0/34 1-4094
Gi1/0/38 1-4094
Gi1/0/39 1-4094
Gi1/0/40 1-4094
Gi1/0/41 1-4094
Gi1/0/44 1-4094
Te1/1/4 364,380,388,396,464,480,3104,3250
Port Vlans allowed and active in management domain
Gi1/0/1 1,20,3400
Gi1/0/13 1,5,10,20,50,80,250,350,352,355-356,364,372,380,388,396,414,464,472,480,488,3104,3112,3250,3400-3402
Gi1/0/15 1,5,10,20,50,80,250,350,352,355-356,364,372,380,388,396,414,464,472,480,488,3104,3112,3250,3400-3402
Gi1/0/24 1,5,10,20,50,80,250,350,352,355-356,364,372,380,388,396,414,464,472,480,488,3104,3112,3250,3400-3402
Gi1/0/29 1,5,10,20,50,80,250,350,352,355-356,364,372,380,388,396,414,464,472,480,488,3104,3112,3250,3400-3402
Gi1/0/31 1,5,10,20,50,80,250,350,352,355-356,364,372,380,388,396,414,464,472,480,488,3104,3112,3250,3400-3402
Gi1/0/33 1,5,10,20,50,80,250,350,352,355-356,364,372,380,388,396,414,464,472,480,488,3104,3112,3250,3400-3402
Gi1/0/34 1,5,10,20,50,80,250,350,352,355-356,364,372,380,388,396,414,464,472,480,488,3104,3112,3250,3400-3402
Gi1/0/38 1,5,10,20,50,80,250,350,352,355-356,364,372,380,388,396,414,464,472,480,488,3104,3112,3250,3400-3402
Gi1/0/39 1,5,10,20,50,80,250,350,352,355-356,364,372,380,388,396,414,464,472,480,488,3104,3112,3250,3400-3402
Gi1/0/40 1,5,10,20,50,80,250,350,352,355-356,364,372,380,388,396,414,464,472,480,488,3104,3112,3250,3400-3402
Gi1/0/41 1,5,10,20,50,80,250,350,352,355-356,364,372,380,388,396,414,464,472,480,488,3104,3112,3250,3400-3402
Gi1/0/44 1,5,10,20,50,80,250,350,352,355-356,364,372,380,388,396,414,464,472,480,488,3104,3112,3250,3400-3402
Port Vlans in spanning tree forwarding state and not pruned
Gi1/0/1 1,20,3400
COM3-EDGE01#show interfac trunk
Te2/0/1 on 802.1q trunking 3250
Gi5/0/2 on 802.1q trunking 3250
Te2/0/1 364,380,388,396,464,480,3104,3250
Gi5/0/2 364,380,388,396,464,480,3104,3250
here is the output of the last edge switch, interestingly the 10gb connection is not listed in the output even though it's trunking.
COM4-EDGE03#show interface trunk
Gi1/0/5 on 802.1q trunking 3250
Gi1/0/5 364,380,388,396,464,480,3104,3250
COM4-EDGE03#show run int te 1/0/1
Building configuration...
Current configuration : 241 bytes
description Link to agg
end
the show interface TenGigabitEthernet1/0/1 switchport command?
Configure terminal
Can you apply it again?
Additionally you can remove the command from the interface
no spanning-tree bpduguard disable
Recommendations for using BPDU Guard
Enable BPDU Guard on ports that should not receive BPDUs from any device.
Use BPDU Guard on ports that are directly accessible by end-user devices, such as laptops and mobile phones.
Use BPDU Guard to prevent an access port from participating in spanning tree.
