need DHCP help
llessur4484
I have no idea why I cannot get DHCP to work?? can I get some help? would be greatly appreciated. heres the link:
ENABLE PASS IS CIASS
https://drive.google.com/file/d/1EdBuLulDbR57cOYlvIcmM2qZfKZUFDJh/view?usp=sharing
10 Replies 10
Diana Karolina Rojas
Please send the enable pass.
Best Regards,
I edited my post. It is class
I have many doubts about your network Why your routers does not have a subinterface for vlan 100 or vlan 200? where is the gateway for these vlans? why your access ports are trunk? If the router will not be router on a stick why do you not configure a /30 between the router and the switch?
Best Regards,
I can add subinterfaces for 100 and 200. should I do that? how do I create a gateway for vlan 100 and 200? my professor set up the topology and ip addresses. should I make access ports access? thanks!
balaji.bandi
Sorry not able to Open the file due to company policies here.. can you paste the error you getting, so i try to help you.
BB
BB
it says apipa being used. you would really need to look at it...
Look at this post may be helpful
https://learningnetwork.cisco.com/thread/103244
BB
BB
llessur4484
any solutions?
bump
BB
BB
