Need help configuring vty lines
beckman3
Frequent Visitor
Frequent Visitor
We recent replaced a ISR 4331 router and I had incorrectly configured the VTY lines. Now I am trying to get them configured to the way I need them but I am having no luck.
This is how the vty lines are configured currently:
line vty 0
   exec-timeout 0 0
   no activation-character
   no exec
   transport preferred ssh
   transport input none
   stopbits 1
line vty 1 4
   exec-timeout 0 0
   privilege level 15
   transport input ssh
This is how i would like them to be:
line vty 0 4
   privilege level 15
   transport input ssh
I understand that you cannot remove vty lines and re add them so to get them combined they need to configured the same. I am having trouble getting line vty 0 and line vty 1 4 configured the same to get them to be combined.
Any help is greatly appreciated! Thank you!
Luke
Julio E. Moisa
Try resetting the config:
default line vty 0 4
default line vty 5 15
Once it is reset you can apply your config.
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
johnd2310
Level 11
Level 11
Have you tried deleting all the current configuration from the lines and adding the new configuration?
John
**Please rate posts you find helpful**
Julio E. Moisa
Hope it is useful
