08-31-2019 12:55 PM
Hi!
I'm trying to get my switch to route traffic from my WAN (Vlan 1), to the INSIDE (Vlan 2) and can't seem to get it working.
-i'm still quite new to playing around with Cisco L3, and I feel that I have hit a dead end here.
Hope someone here is able to help me understand, what i'm doing wrong.
Here is my output of "show run":
S1-3560#show run
Building configuration...
Current configuration : 2555 bytes
! Last configuration change at 00:05:57 UTC Mon Mar 1 1993 by admin
version 15.0
no service pad
service password-encryption
hostname S1-3560
boot-start-marker
boot-end-marker
username admin privilege 15 password 7 XXXXXXXXXXXXXXXXXX
no aaa new-model
system mtu routing 1500
ip routing
ip domain-name S1-3560
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip dhcp excluded-address 10.0.0.1 10.0.0.10
ip dhcp pool LAN/INSIDE
network 10.0.0.0 255.255.255.128
default-router 10.0.0.1
dns-server 8.8.8.8 8.8.4.4
ip address-pool dhcp-pool
spanning-tree mode pvst
vlan internal allocation policy ascending
interface Loopback0
ip address 10.0.0.254 255.255.255.128
interface FastEthernet0/1
description LAN/INSIDE
switchport access vlan 2
switchport mode access
power inline never
interface FastEthernet0/2
power inline never
interface FastEthernet0/3
power inline never
interface FastEthernet0/4
power inline never
interface FastEthernet0/5
power inline never
interface FastEthernet0/6
power inline never
interface FastEthernet0/7
power inline never
interface FastEthernet0/8
power inline never
interface GigabitEthernet0/1
description WAN/OUTSIDE
interface Vlan1
ip address dhcp
ip access-group 100 in
ip access-group 100 out
interface Vlan2
ip address 10.0.0.1 255.255.255.128
ip default-gateway 10.0.0.1
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 dhcp
logging esm config
access-list 100 permit ip any any
access-list 100 permit udp any eq domain any
access-list 100 permit udp any any eq domain
access-list 100 permit icmp any any
line con 0
logging synchronous
login local
length 0
line vty 0 4
logging synchronous
login local
length 0
line vty 5 15
logging synchronous
login local
length 0
end
S1-3560#
Thanks in advance
-Bjerremann
Solved! Go to Solution.
08-31-2019 01:52 PM - edited 08-31-2019 01:54 PM
you need to have below statement :
you do not need loopback interface(until you need any other purpose)
no interface Loopback0
ip address 10.0.0.254 255.255.255.128 <<-- this is wrong subnet
To reach internet you need to have NAT in place ? for your LAN, so you have any other device doing NAT ?
since you are allowing all you do not need ACL ?
08-31-2019 01:44 PM
I see this in your config
nterface Vlan1
ip address dhcp
Does this mean this switch is connecting to the Internet? If yes, your internal IP is private and you need to do NAT but this switch does not support NAT.
Can you confirm?
08-31-2019 01:54 PM - edited 08-31-2019 01:55 PM
Thank you, for the reply HTH.
That is correct.
But maybe I misunderstood something then?
I read somewhere that you could use the "ip routing" on this switch, instead of "ip nat" - and then use this switch almost as a router with fewer options.
That's why I conf'ed the switch with the "ip route 0.0.0.0 0.0.0.0 dhcp".
08-31-2019 03:07 PM
You need a router to do the NAT for you. Almost all switches (except the 6500 and 6800 series) don't support NAT.
08-31-2019 02:25 PM
