Need help on " Interface Showing Inactive on cat4500".
gkchakravarthy
We have 3 Cat 4500 switches on three floors teh 3rd floor switch connects to the 2nd and 4th floor switches ,but we are receiving an alert from monitoring tool that " Interface(314) Backup-1Gb-Ring is Down at least 2 min on Switch: SOM500-4510-3FL
the following output from "sh int status module 1 " shows the int 1/3 and 1/4 are 'inactive'local IT guy said If the status is inactive,the ports cannot be used and might lost the capability when he added 48-port blade into the 10th slot.Can someone help try to identify the issue here.
2nd Floor
Port      Name               Status       Vlan       Duplex  Speed Type
Te1/1     SOM500-Core1       connected    trunk        full    10G 10GBase-LRM
Te1/2     SOM500-Core1       connected    trunk        full    10G 10GBase-LRM
Gi1/3     Backup-1Gb-Ring    notconnect   1            full   1000 1000BaseSX
Gi1/4     Backup-1Gb-Ring    connected    trunk        full   1000 1000BaseSX
3rd Floor
Gi1/3     Backup-1Gb-Ring    inactive     1            full   1000 1000BaseSX
Gi1/4     Backup-1Gb-Ring    inactive     1            full   1000 1000BaseSX
Gi1/5                        inactive     1            full   1000 No Gbic
Gi1/6                        inactive     1            full   1000 No Gbic
4th Floor
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500-IPBASEK9-M), Version 12.2(31)SGA10, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Fri 12-Jun-09 15:33 by karnagar
Image text-base: 0x10000000, data-base: 0x115D7330
ROM: 12.2(31r)SGA3
Pod Revision 16, Force Revision 34, Tie Revision 32
SOM500-4510-4FL uptime is 1 year, 38 weeks, 1 day, 10 hours, 26 minutes
Uptime for this control processor is 1 year, 38 weeks, 1 day, 9 hours, 37 minutes
System restarted at 23:29:54 EDT Sun May 1 2011
System image file is "slot0:cat4500-ipbasek9-mz.122-31.SGA10.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C4510R (MPC8540) processor (revision 11) with 524288K bytes of memory.
Processor board ID FOX091404HA
MPC8540 CPU at 800Mhz, Supervisor V-10GE
Last reset from PowerUp
2 Virtual Ethernet interfaces
340 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
6 Replies 6
cmarva
Level 4
Level 4
would you be able to post the port configs of g1/3 and g1/4?
the only time I've ever seen inactive is when a port was set to a vlan that didn't exist
on the switch, but vlan 1 can't be removed, so.....
chris
Hi Chris,
find the detais below
interface GigabitEthernet1/3
description Backup-1Gb-Ring
switchport trunk native vlan 500
switchport mode trunk
ip arp inspection trust
ip dhcp snooping trust
end
interface GigabitEthernet1/4
end
ok, thanks.
doesn't look like anything is out of the ordinary. So getting back to my last post, does vlan 500 exist on the switch?
Also do a sho int trunk. I don't see any vlan allowed/removed statements so I assume the default of 1-4094 allowed on
the trunk. If a sho int trunk shows no vlans allowed on the trunk, then I think that's your problem.
also, getting back to my last post, disregard about the vlan 1 statement. My error.
chris
Chris
Thanks for your reply
include out from sh int tru
SOM500-4510-2FL#sh int trunk module 1
Port        Mode             Encapsulation  Status        Native vlan
Te1/1       on               802.1q         trunk-inbndl  500
                                      (Po2)
Te1/2       on               802.1q         trunk-inbndl  500
                                      (Po2)
Gi1/3       on               802.1q         other         500
Gi1/4       on               802.1q         trunking      500
Gi1/5       auto             negotiate      other         1
Gi1/6       on               802.1q         trunking      500
Port        Vlans allowed on trunk
Te1/1       1-4094
Te1/2       1-4094
Gi1/3       none
Gi1/4       1-4094
Gi1/5       none
Gi1/6       1-4094
Port        Vlans allowed and active in management domain
Te1/1       1,4,10-11,15,20-22,25-27,30-35,40-41,45,57-58,60-62,64-70,72-77,100-102,111-114,128,161,180,182,184,200-202,212,254-255,301-302,401-402,500
Te1/2       1,4,10-11,15,20-22,25-27,30-35,40-41,45,57-58,60-62,64-70,72-77,100-102,111-114,128,161,180,182,184,200-202,212,254-255,301-302,401-402,500
Gi1/3       none
Gi1/4       1,4,10-11,15,20-22,25-27,30-35,40-41,45,57-58,60-62,64-70,72-77,100-102,111-114,128,161,180,182,184,200-202,212,254-255,301-302,401-402,500
Gi1/5       none
Gi1/6       1,4,10-11,15,20-22,25-27,30-35,40-41,45,57-58,60-62,64-70,72-77,100-102,111-114,128,161,180,182,184,200-202,212,254-255,301-302,401-402,500
Port        Vlans in spanning tree forwarding state and not pruned
Gi1/3       none
Gi1/5       none
Gopineni,
ok, thanks. What I am not sure of is whether or not it shows no vlans allowed on trunk because it is inactive,
or if it is inactive because there are no vlans allowed on the trunk, I believe it is inactive because no vlans are allowed
on the trunk.
Are these links in use or connected to anything? If not, I would reset them to default config and shut them down
(default interface g1/3, default interface g1/5).
If they should be in use, and that's what you are troubleshooting, then
just adding vlans allowed should bring it back into service. Going by the descriptions, this might not be a good test
scenario, but you can always add a vlan that is not on the other trunks. For instance, add vlan 80 as an allowed vlan and
see if it comes out of inactive state.
Ok Chris will test and post the results.
Thank You.
