Need Help on VLAN Communication
sachinc01
Hi Team,
Please find attached layout I have 100,200,300,400 VLAN on SG500X L3 switch
On SG300 Switch on L2 Mode All VLAN replicate on L2 Switch nOw all VLAN communicate each other.
Please Guide :- I want to set all VLAN didnot communicate each other but access SERVER VLAN 400 & Internet
VLAN 100 :- Communicate VLAN 100 & VLAN 400 Server & Internet 192.168.1.1
VLAN 200 :- Communicate VLAN 200 & Vlan 400
VLAN 300:- Communicate VLAN 300,100,400
How I will Set please guide.
Hello
Routed access-list (RACL) would be good a good solution
ip access-list extended vlan100
deny ip 192.168.2.0 0.0.0.255
permit ip any any
int vlan 100
ip access-group vlan100 out
ip access-list extended vlan200
deny ip 192.168.1.0 0.0.0.255
permit ip any any
int vlan 200
ip access-group vlan200 out
ip access-list extended vlan300
Permit tcp 192.168.1.0 0.0.0.255 any established
Permit tcp 192.168.3.0 0.0.0.255 any established
deny ip 192.168.3.0 0.0.0.255
permit ip any any
int vlan 300
ip access-group vlan300 out
Note for vlan 300 the Acl is allowing tcp ONLY if you wish UDP also then it will have to be any any ace entry due to the connection-less nature of the protocol
res
Paul
Kind Regards
Paul
