need help to select a managed switch!!!!
ciskay009
Dear friends,
I have to put a managed switch in my offcie to control and monitor the internet usage in my network, and at the same time, I have to select a managed switch which will help me to get hands on experience with all the cisco commands and configuration using commanly in all the cisco switches models.
So kindly help me and let me know for which switch should I go which meet my requirements as stated.
Thanks in advance for all supporters.
5 Replies 5
Latchum Naidu
Hi Khaja,
You just told to be able to manage the switch apart from this there is no other requirement.
I would suggest SRW224G4
The Cisco SRW224G4 Gigabit Switch allows interconnection of up to 24 separate network devices. Throughput is essential, and this switch delivers optimal speeds on the connection level.
Prioritize and structure your network traffic with the SRW224G4 using a variety of techniques that keep your need for data redundancy and continuous uptime at the forefront of the discussion. Multiple clients can access the switch's robust management functions, and its internal monitoring software watches over your network's every move.
Additional features of the Cisco SRW224G4 Gigabit Switch include:
  • Non-blocking switching capacity of up to 12.8 Gbps
  • Up to 256 active port- and 802.1q-based VLANs (4096 range)
  • Secure access limitations using 802.1x port authentication and MAC filtering
  • Optimized for growing businesses with four expandable Gigabit uplink ports
  • IGMP snooping, L2/L3 COS, queuing & scheduling makes solution ideal for voice/video
  • Intelligent traffic management with rate limiting, policing, shaping, and storm control
Please rate the helpfull posts.
Naidu.
Somasundaram Jayaraman
The best way to select switches is to refer the Data sheet. However i would go for 3750, because it is simple and powerful for access layer.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5023/product_data_sheet0900aecd80371991.html
For core,
6500 switches.
Some useful links in product selection.
- http://www.cisco.com/en/US/products/hw/switches/products_category_buyers_guide.html
- http://www.cisco.com/en/US/products/ps6406/prod_models_comparison.html
-http://www.cisco.com/en/US/products/ps10745/prod_models_comparison.html
Cisco feature navigator is a tool used to select the products using feature, image etc. Below is the link for it.
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Hope this helps.
Cheers
Somu
Rate this answer if you find the content was useful
Collin Clark
Well I would suggest one of the models between the SRW224G4 and the 3750. The 3560X is a great switch. It as the full IOS features you're looking for. You can also get PoE, redundancy, and layer 3 IOS of if you require it in the future (or now). It also has the same performance as the 3750, but it's more cost effective. Post if you have further questions on the model comparison.
hobbe
Level 7
Level 7
I would go with the 3750x with ip services.
Why ? Well you would be able to do all the things you need to with it and still be able to have 10gig if need be.
the 3560x is a good second choise but i am not shure you will be able to test things like stacking and so on.
if you get the 3750x you can rent/borrow another 3750 and test stacking and so on.
if you need to test the adv ip services then you are able due to a test license that comes with the system.
that will give you alot more things to test such as eem and better routing abilities.
Good luck
ciskay009
Dear all,
Thanks for your replies and well everyone given me your best suggestion, and now I have to find out the one suits me with my budget and requirment among the models SRW224G4 (naidu), 3750x (jayram,hobbe,and collin), 3560X.
Any have you guys release my burden some what, and thanks Mr. jayaram, I will look now the links you have sent.
FYKI I am CCNA certifiied and I have only knowledge about the switch and router, and the on coming project of placing switch to my office will help me to get familiar with switch configuration.
